It is currently Sat Aug 16, 2025 7:42 pm
PostPosted: Mon Oct 29, 2012 11:10 pm
Give Ash some flowers Nick .
Hey everyone,
I'm struggling getting the last bolt in of my new rear adjustable camber brackets. I can't seem to get the arm down far enough to get the top bolt in.
Is there a trick to it? Do I need to deflate the hydro? (I have a pump so I don't mind letting it down).
This seems like a common mod for minis and I have no idea how people get past this point!
Any suggestions would be appreciated.
Thanks, Nick
 Post subject: Castor brackets.
PostPosted: Tue Oct 30, 2012 4:08 am
I presume you are talking about the rears. Sometimes you might have to elongate the holes to make it easier, otherwise you will damage the thread and that will be a problem..
"Let us remove your "SHORTS"
PostPosted: Tue Oct 30, 2012 12:43 pm
Nick, I did mine a couple of weeks ago. Luckily dad helped out he was able move the arm using a lever, to get it in just the right place for me to put the bolt in. Two man job made it easier.
EDIT: No I didn't let the hydro down either.
PostPosted: Tue Oct 30, 2012 2:16 pm
remove the other bolts and check that the holes do actually line up properly
then use a pry bar between the arm and the subframe
PostPosted: Tue Oct 30, 2012 4:24 pm
yeah quite often those brackets don`t have the holes in the right places & need a bit of a mod
& yes also you`ll need a bit of a lever to get it all to line up
oops, double de-bug post
oops trippple de-bug post
PostPosted: Tue Oct 30, 2012 7:42 pm
I hope that's a finger/brain stutter Matt, not a palpitation! :P
Users browsing this forum: No registered users and 237 guests
