It is currently Thu Aug 21, 2025 1:18 pm
PostPosted: Thu Nov 01, 2012 5:24 pm
Guys
Whats the best way to get the body up in the air to remove the Engine and subframe?
Lift points etc...
PostPosted: Thu Nov 01, 2012 5:29 pm
I assume you mean where do you lift it? If you have engine crane, lift with sling onto holes on inner guards brace, the angle bit that goes from fire wall crossmember to inner guard.
PostPosted: Thu Nov 01, 2012 5:47 pm
Yep, I agree with that, but you ideally want lots of height to get the sling angles closer to vertical. I use a ceiling mounted block and tackle, nice and high.
PostPosted: Thu Nov 01, 2012 7:34 pm
Like this...
sort of.
PostPosted: Thu Nov 01, 2012 8:30 pm
I've always used a couple of trolley jacks to start off and then two or three string blokes to finish.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Nov 01, 2012 10:25 pm
Brett do you use any special knots to make these string blokes? :lol:
Alec
PostPosted: Thu Nov 01, 2012 11:07 pm
Haha a freudian slip perhaps :-) , maybe he meant three G string blokes :lol:
PostPosted: Fri Nov 02, 2012 9:24 am
Stupid bl**dy phone!!
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: Bing [Bot] and 214 guests
