It is currently Mon Aug 11, 2025 12:31 am
PostPosted: Tue Nov 20, 2012 8:00 pm
Does anyone have recommended wheel alignment settings for sports road use? The car is a standard hydro setup (no dampers) if that makes any difference.
PostPosted: Tue Nov 20, 2012 8:09 pm
a good starting point is
front toe out = 1/16th"
caster = 3 or 4 deg
camber = neg .5deg
rear toe in = 1/16th"
camber = neg .5 deg
PostPosted: Tue Nov 20, 2012 8:57 pm
I agree, that's what mine is set at, it steers well, only difference is I have Pedders (same as Gabriel reds I think) dampers on the front.
[edit] woops I have -1.5° camber on front not -0.5°.
Last edited by drmini in aust on Wed Nov 21, 2012 3:54 pm, edited 1 time in total.
PostPosted: Wed Nov 21, 2012 3:49 pm
caster = 3 or 4 deg
camber = neg .5deg
camber = neg .5 deg
Mine is exactly what Matt has said except I have -1.5 non adjustable lower arms on the front. Handles like a dream 8)
PostPosted: Thu Nov 22, 2012 3:35 pm
I use standard toe-in at front (<1/8") and <1 deg. neg. camber at all 4 corners and zero toe (O") at rear and +3 deg. caster up front.
But my Minis have been long haul drivers in North America. Zero toe at rear will both aid cornering and track with less tire wear in long haul driving.
I use adjustable hi-los (height), heim jointed lower arms (camber), adj. tie rods (caster) at front and adj. height, shims (toe) and camber brackets at rear.
Ride height is a non-standard 2 1/2 fat fingers (my fingers) between top of tires and wheel arch.
It works.
Users browsing this forum: No registered users and 183 guests
