It is currently Wed Jul 23, 2025 12:38 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Dec 24, 2012 9:51 pm
Buy carbon fibre ones! Bonnet, boot, roof, front end, a panels, boot floor, parcel shelf, floor pans, bumpers, headlight rims etc are all available in carbon fibre
PostPosted: Tue Dec 25, 2012 6:10 am
this one has alloy door skins too
PostPosted: Tue Dec 25, 2012 10:54 am
And an alloy engine which has to be lighter than the A series :lol: .
PostPosted: Tue Dec 25, 2012 4:46 pm
How do standard doors perform in side impacts? I'd be more concerned about adding an intrusion bar and looking elsewhere...
Alec
PostPosted: Tue Dec 25, 2012 8:19 pm
Pulled one of the door bins off today. (Couldn't help but get in the garage) Found some rust in the process.
If its yours, customize it !
PostPosted: Tue Dec 25, 2012 8:26 pm
Rust is light :wink:
PostPosted: Tue Dec 25, 2012 8:32 pm
Rust is light
I should of gone rat rod then
Actually, rust is heavier than steel (burn some steel wool to FeO2 and weigh it if you don't believe me). It's the holes it leaves that is light.. :lol:
PostPosted: Tue Dec 25, 2012 8:40 pm
That's why I suggested it may be illegal to cut up the doors, more so the Leyland mini doors built to comply with ADR's.
Ideally I'd like to fit a 6 point roll cage welded to the A, B and C pillars and incorporate very good side intrusion bars then I'd be happy to fit carbon fiber doors.
PostPosted: Tue Dec 25, 2012 9:55 pm
Then you'll need a helmet to drive to the shops!
PostPosted: Tue Dec 25, 2012 11:07 pm
Why :?: :?
PostPosted: Wed Dec 26, 2012 7:52 am
Why :?: :?
To complete the image and perhaps a drivers suit too. 8)
Oh! Gloves too
PostPosted: Wed Dec 26, 2012 7:17 pm
Why :?: :?
For when you hit your head on the bit of pipe that is an inch away from it.
PostPosted: Wed Dec 26, 2012 8:56 pm
What is going to protect your head from the steel bars which are inches from your head when you do roll over?
This is the real reason why full roll cages are not road worthy in some states. Nothing to do with body integrity or strength
PostPosted: Wed Dec 26, 2012 8:59 pm
Properly built they can be roadworthy - but the rules are pretty tight these days.
