It is currently Mon Jul 21, 2025 5:40 pm
PostPosted: Wed Dec 26, 2012 7:05 pm
Could anyone tell me where i could find parts as have a leaking one. I have an early mark 2 cooper S- new to the forum.
Scott.
PostPosted: Wed Dec 26, 2012 7:14 pm
You can get these parts locally, but I used these guys in the UK last time because the parts are right there on the screen and easily ordered.
http://www.jlspares.com/sealkits1.htm
Yours will be the Lockheed 5 1/2. Don't order the parts without inspecting the chrome plated pushrod first, and avoid fiddling with the air valve if you have to, they're hideously expensive if broken.
PostPosted: Wed Dec 26, 2012 7:22 pm
Thanks Mick,
which is the air valve, is that the valve on the bottom with five phillips screw? If it is the the diaphraghm was full of brake fluid.
PostPosted: Wed Dec 26, 2012 8:11 pm
Yes it is that one, try not to tear that diaphragm as while the material is quite normal, it needs to have its particular centre pressed in which makes it a little expensive (40 pounds).
There's a cup shaped seal underneath the little piston the air valve sits on when its in place. This one goes directly into the cylinder and will be where the fluid is leaking from. Easy fixed once you get the little piston out.
If the main and air valve diaphragms are in good shape then you will just need a basic seal kit. Check the condition of the pushrod to see if the chrome has lifted. J&L have the replacements.
I had to use a grease gun to get mine out, it was rusted in place.
Air valve
PostPosted: Wed Dec 26, 2012 8:26 pm
Thanks so much Mick for your help.
The rubber diaphragm in the vaccuum chamber has been effected by brake fluid. Should it be replaced ?
PostPosted: Wed Dec 26, 2012 8:30 pm
Its a little expensive, but easy to replace at the same time.
If it looks only cosmetic without any real damage I would make a judgement call to give it a go again.. My main diaphragm is still the original and works fine.
Users browsing this forum: Bing [Bot], fuzzy-hair-man and 67 guests
