It is currently Mon Aug 04, 2025 7:27 am
PostPosted: Sun Jan 20, 2013 12:35 pm
I own a Leyland Mini S, and currently have lightweight Hayashi 13" aluminium racing wheels in my possesion. Just wondering if it's possible to buy adapters for these Minis?
Exactly what is the PCD and Boresize for the Leyland S?
Thanks!!
Dan.
PostPosted: Sun Jan 20, 2013 12:48 pm
From memory the mini PDC is 101.6mm but don't quote me on that until someone else backs that up.
However as far as I know a wheel adaptor is illegal in Aus for road use, check with your states transport dept.
PostPosted: Sun Jan 20, 2013 12:51 pm
The Mini is 4 inch PCD which equals 101.6mm.
The Morris 1100 is 4½ inch PCD which equals 114.3mm.
So the easiest solution is to buy a Morris 1100. :mrgreen:
PostPosted: Sun Jan 20, 2013 12:56 pm
Could you re-drill the studs on the hubs :?: is their enough meat their? But then you'll have to drill the drums.
PostPosted: Sun Jan 20, 2013 2:25 pm
Morris 1100 hub swap?
PostPosted: Sun Jan 20, 2013 2:37 pm
Won't work without a lot of machining.
The easiest solution is to buy wheels that fit a Mini.
PostPosted: Sun Jan 20, 2013 3:32 pm
Not enough steell in either of them to re-drill.
PostPosted: Sun Jan 20, 2013 3:56 pm
Haven't people drilled the holes out bigger and fitted thicker studs, to get it to the 114?
I think brad did it on his charade powered roundy
You're so square
Baby I don't care
PostPosted: Sun Jan 20, 2013 4:19 pm
You can do that to get the hubs back to 4x100 if you really want.
PostPosted: Mon Jan 21, 2013 12:42 pm
I had offset spacers made to go from mini to 4x100 for madmk1
Expensive at $180 a piece.
They will be for sale soon.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
