It is currently Sun Aug 03, 2025 6:31 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jan 03, 2013 6:20 am
Kennomini wrote:
Not my cup of tea, it's going in a daily driver and I don't want to be sitting on 4700 on the highway, good for a track toy or a weekend warrior.
A 3.93 in a Mini would be a bit silly. But it should be just fine in a big wheeler Moke.
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Jan 03, 2013 7:15 am
I run a 3.647 in my 1360 Mini with 10" wheels, 110KMH on the TomTom GPS is 4600 rpm. It's great everywhere except on the freeway but I don't do much of that. :P
PostPosted: Thu Jan 03, 2013 8:33 am
My wife's 850 has (as far as I know) a 3.76 in it. I briefly ran it up to 110kph on my Tom Tom on the Calder Fwy yesterday. I didn't hold it there long as it sounded mighty busy and I didn't want to damage it. It has no tacho but according to my calculations it was turning around 4500rpm.
Withe the new diff in the Moke on 185/60R13 tyres it should be turning about 3800 at 100kph. Same revs as a Mini on 10's running a 3.44. Just about ideal IMHO. I can always fit taller tyres later if I decide I want to drop the cruising revs a little more.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Jan 04, 2013 11:09 pm
The Mini King
Note the tallest one in cars sold here was the 3.444.
This was used in the Cooper S and most rodchange boxes except the Mokes.
3.647 was used in most remote boxes (Mini K and 1098 Clubby) except Cooper S
3.765 was used in 850, 997 & 998 Cooper, and 998 Deluxe.
3.9 never sold here,
4.13 and 4.26 are found in Mokes and Morris 1100 & 1100S.
I may be wrong
I thought the 3.9375 was fitted to the Moke for a short period
PostPosted: Sat Jan 05, 2013 7:16 am
You could be right John, I forgot about the Mini's ugly cousin. :lol:
PostPosted: Sat Jan 05, 2013 7:50 am
Ive never heard of a Moke with a 3.94 from the factory but it wouldn't surprise me. The only factory application I could find was an Innocenti model.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Jan 05, 2013 8:56 am
Then I'd go for a 3.2 or 3.1 diff esp if you've got loads of power.
Personally I am in love with 3.44 and will stick with that until further notice
PostPosted: Sat Jan 05, 2013 10:35 am
I'd give a 3.1 a go in my car... bit more legs in 1st gear for the big motorkhana tests. Gives 61kph at 7000rpm, up from 55.5kph
I've got plenty of torques to spare :D
PostPosted: Sat Jan 05, 2013 10:43 am
I'm pretty sure I have a 3.1 in my current engine (1990 Rover Cooper 1275 carby). I really like the highway cruising RPM, just a matter of finding a spare one.
PostPosted: Sat Jan 05, 2013 2:53 pm
Ya I'm at the other end of the scale from the Doc - I'd love a 3.1 to quiet down the highway and give some legs to 1st for motorkhanas. Only place to get them is new though $$$
PostPosted: Sat Jan 05, 2013 5:09 pm
Does anyone know what diffs rover minis came out with?
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sat Jan 05, 2013 6:42 pm
Considering most Rovers were on bigger wheels I'd say compare them to mokes.
PostPosted: Sat Jan 05, 2013 8:53 pm
Rovers had lower profile tyres on their 12" rims so the overall diameter is only a little bit bigger. As stated above, the mini was well past its used by date when still being sold in the 90's and had trouble complying with modern regs. The ultra tall diff was purely a drive-by noise test thing. I remember reading road tests of minis before the 1275 reappeared and every one lamented the gearing.
PostPosted: Mon Jan 28, 2013 9:41 am
Are the A+ crownwheel and pinion different to pre A+?
The likes of minispares.com make mention of the fact that certain ratios are A+; is this just down to the fact that they originally came fitted to A+ boxes, or that they are somehow different / incompatible?
'68 Deluxe w/Metro engine
PostPosted: Mon Jan 28, 2013 10:20 am
They are different tooth profile to A series and must be fitted as a set (ie both gears A+).
But all ratios can be put in an early box, however 3.2:1 and taller need the mainshaft bearing's retainer plate bored out to clear the bigger pinion.
Users browsing this forum: timmy201 and 83 guests
