It is currently Wed Aug 13, 2025 9:15 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Feb 05, 2013 8:13 pm
Check the compression on #3 and #4 first. Usually when these 2 are not working on a smallbore, the gasket is blown between them. However it could be other things if not run for a while. Like suppression type plug leads gone open circuit coz they are too old.
[edit] typos...
Last edited by drmini in aust on Tue Feb 05, 2013 8:30 pm, edited 1 time in total.
PostPosted: Tue Feb 05, 2013 8:27 pm
jorgan92 wrote:
Good News - Engine started and ran on Saturday WOOOHHOOO!!!! :D
Bad News - It's only running on two cylinders -.-
After trying everything, have determined it is not getting any fuel in the cylinders (3&4), it has twin SU's on it , so I'm assuming I'm going to need to re build these, woopie!
Now they were re-built something like 6 years ago now and have probably had no more than 3 hours of actual use time in those 6 years, is there going to be an easy solution or something to look for? Some thing in the float stuck? I'm not sure I haven't played to Carby's too much, but from what I hear SU's aren't too hard, so I might start.
Does anyone have any tips? Good guides to re-build them? A list of parts?
Any help is greatly appreciated.
You guys are legends.
Jordan
Well answering after the Doc is scary but here goes :-) , try the easy things first .Make sure your getting fuel to both carbies .
So 1 do docs suggestions .
2 just some ideas im throwing out there i would check both bowls are full of petrol ,check dashpot oil is at the correct level check linkages and cables as your running dual carbies , Fuel filter installed ? as you said they probably have only done a few hours since rebuild so ......
....... and this is how i got pickles running and not for the squeamish :-) have some one pour petrol down the carbies till she fires " mum did it for me :-) " didnt mention blow back can cause a fire in your pouring cup as happened on an old xw ford of mine many many years ago " ahh good times ", as i said it worked for pickles but i only have a single carby .
Try simple stuff first then worry if that didnt work thats my theory anyway then ask Doc :-) and the many many mini masters on here.
Cheers Bill
PostPosted: Tue Feb 05, 2013 8:41 pm
So already done:
Check leads (swapped with one and two)
Swapped Spark Plugs
Checked for Spark
Clamped fuel line to the carby on the right, made no difference.
Hmmm, compression WOOO! Fun, will check it out tomorrow If I can find the tester somewhere, any ideas on what its meant to be? My guess for old cars is above zero? :P
I have to say I love how easy it is to crank the engine over in the engine bay, it makes all this ALOT easier to do by your self.
Thanks for all your help.
PostPosted: Tue Feb 05, 2013 8:43 pm
If you can't find the tester stick yer thumb over each plughole in turn whilst someone cranks it. It'll be obvious if the gasket's blown, there will be sfa pressure in both those cylinders.
PostPosted: Tue Feb 05, 2013 8:45 pm
If the carbies haven't been used for a while I would just give them a good clean
Probably just some crud stuck somewhere
First remove the lids of the float bowls and check for fuel
Then remove the damper and check the needle moves up and down
I would also remove the top and check all is ok with the needle and jet
Not much else but clean out and make sure it has fuel
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Feb 05, 2013 8:49 pm
90% certain it's in the back of the Escort :P
Time to get out a manual and make sure I know which part is which :P But thank you very much for the suggestions.
PostPosted: Thu Feb 14, 2013 6:11 am
So compression is fine.
Pulled apart the carby and everything appears to be fine and working properly, put it back together and tried to start it.
Wouldn't quite start so dad said to put something over the intake to act as a choke (choke cable not hooked up at the moment I have lost the screw).
So I did that, started up straight away, running on all 4, but when I take the thing (old t-shirt) off the intake it goes back to running on 1&2.....
Any suggestions guys?
Jordan
PostPosted: Thu Feb 14, 2013 6:53 am
The carb could be too lean, and because of the siamesed centre bores they are leaning out past the point they can fire.
You could try get your hands on one larger carb, this would eliminate charge robbing as a culprit.
You didn't tell us what twins you had?
PostPosted: Thu Feb 14, 2013 7:00 am
Which cylinders are the "siamesed centre bores"?
Steve
PostPosted: Thu Feb 14, 2013 10:06 am
Twin 1&1/2" SU's (I think) they're bigger than the standard Cooper S ones which I think are 1&1/4?
PostPosted: Thu Feb 14, 2013 11:29 am
Police coopers had the inch and a half carbs and standard had the inch and a quarter carbs.
Hooroo
Rob Forsyth
Miniot!!
Users browsing this forum: No registered users and 241 guests
