jorgan92 wrote:
Good News - Engine started and ran on Saturday WOOOHHOOO!!!!
Bad News - It's only running on two cylinders -.-
After trying everything, have determined it is not getting any fuel in the cylinders (3&4), it has twin SU's on it , so I'm assuming I'm going to need to re build these, woopie!
Now they were re-built something like 6 years ago now and have probably had no more than 3 hours of actual use time in those 6 years, is there going to be an easy solution or something to look for? Some thing in the float stuck? I'm not sure I haven't played to Carby's too much, but from what I hear SU's aren't too hard, so I might start.
Does anyone have any tips? Good guides to re-build them? A list of parts?
Any help is greatly appreciated.
You guys are legends.
Jordan
Well answering after the Doc is scary but here goes
, try the easy things first .Make sure your getting fuel to both carbies .
So 1 do docs suggestions .
2 just some ideas im throwing out there i would check both bowls are full of petrol ,check dashpot oil is at the correct level check linkages and cables as your running dual carbies , Fuel filter installed ? as you said they probably have only done a few hours since rebuild so ......
....... and this is how i got pickles running and not for the squeamish
have some one pour petrol down the carbies till she fires " mum did it for me
" didnt mention blow back can cause a fire in your pouring cup as happened on an old xw ford of mine many many years ago " ahh good times ", as i said it worked for pickles but i only have a single carby .
Try simple stuff first then worry if that didnt work thats my theory anyway then ask Doc
and the many many mini masters on here.
Cheers Bill
Project Pickles is ALIVE!!!!!
Click Here!
