It is currently Mon Aug 04, 2025 5:20 am
 Post subject: Door hinges
PostPosted: Thu Feb 07, 2013 5:50 pm
Do all 4 door hinges have to be different or can some of them be the same , talking about the markings UR ,LR , LL , UL ,.
PostPosted: Thu Feb 07, 2013 6:00 pm
They are all different but I don't think all were marked.
Top hinges are angled in at the top edge, bottom ones are angled out (but much less) at the top edge...
 Post subject: Re: Door hinges
PostPosted: Thu Feb 07, 2013 6:34 pm
The Mini King
If they do not have UR, LR, Etc they will have other Markings such as numbers, that indicate where the fit
PostPosted: Thu Feb 07, 2013 6:52 pm
so they do have to be 4 different ones ?
PostPosted: Thu Feb 07, 2013 6:54 pm
The Mini King
Yes For Sure
PostPosted: Thu Feb 07, 2013 7:03 pm
Thank you.
PostPosted: Thu Feb 07, 2013 7:28 pm
The Mini King
My Last Reply may have been a little short sorry about that, However it is very Important that the correct hinges are used in there places
PostPosted: Thu Feb 07, 2013 8:08 pm
I would add it is also important that the top hinges have the special angled alloy washers on, if not the door skin deforms when you tighten the nuts up.
PostPosted: Thu Feb 07, 2013 8:48 pm
The Mini King
Kev is Spot on, You should also have a Big Thin washer on the Stud that is in the narrow end of the Hinge on the door
