It is currently Thu Jul 31, 2025 6:03 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Mar 07, 2013 1:51 pm
They are only 52 teeth x 3/8 pitch. Neither Dayco or Gates list a 52 tooth belt in 3/8 pitch, although both make them.
There is a Mini kit available in UK now which has an idler pulley, but it uses a 52T belt too. No room on a Mini to use a longer one.
http://www.shengineering.co.uk/sh/conte ... g-belt-kit
These were using Dayco's belt but they are having trouble getting them. Somebody has now bought exclusive rights.
The Gates Kevlar belt (Japanese) is supplied only to Mini Mania in USA.
The gates catalogue I have in front of me lists 9 different 3/8pitch belts with 52 teeth not including their racing series (kevlar) can you provide more info to narrow it down? I'll post a pic later if I can. Nothing I can find by that part number I'm guessing its a superseded dayco part number but retailers often obfusicate their part numbers for obvious reasons.
Unless I've misunderstood the whole dilemma.
PostPosted: Thu Mar 07, 2013 2:15 pm
I know Gates makes kevlar ones, I bought one from Mini Mania US but it's on my car.
But a year or 2 ago both myself and Karcraft chased the part number with Gates here in Sydney, with no joy. All they would say was not available.
Here's a pic of the Gates Kevlar one-
http://www.minimania.com/part/C-AJJ3328 ... evlar-Race
My last new belt is marked `Dayco 052 S 190 Isoran 052 R 190'.
It is 52 teeth, 3/8 pitch, 19mm wide.
Sides of teeth are angled, bottom is flat, they are not involute curved like Nissan etc belts.
The Dayco timing belt catalog I checked online this week had no 52T belts listed.
PostPosted: Thu Mar 07, 2013 3:18 pm
Main benefits are on a race motor. They absorb less power and don't stretch like a chain,
The fact that they do this seems to defy logic. The fact that a metal item stretches more than something that is flexible and partly made up of rubber :roll:
PostPosted: Thu Mar 07, 2013 3:36 pm
Actually it is not flexible in the way you are referring to. Yes it bends but it is woven kevlar reinforced so it does not stretch. Next time you get hold of kevlar, try to stretch it :shock: Bullet proof vests don't stretch, but are flexible. The rubber you refer to is almost just a coating...
Two totally different things. It's like saying a Samurai Sword or leaf spring suspension because it bends and flexes can also change length by stretching it. Totally not true
Chains wear in the many hundreds of micro linkages and pins and hence length increases, not actually stretch. Steel doesn't stretch all that much either...
PostPosted: Thu Mar 07, 2013 3:41 pm
mini_mad_matt wrote:
I'm curious why they only guarantee 40k? Is it purely because there is no tensioner to take up any slack or is it simply at the end of it's life?
Usually it is the width of the belt - the Suzuki G13b has a belt service life of 40k for a Mk1 and 60k for a Mk2 or 3. The Mk1 has a 20mm wide belt, the others a 25mm, so it takes longer to wear & fail.
There are only 52 teeth on the belt mate. So, it goes around a zillion times more often than a twincam one does.
Well, the belt length in a mini does meant the teeth get more wear, but long belts like my Porsche with a 1" x 219 teeth (and a belt that is over 2m long!) not only stretches over time but must compensate for the thermal expansion of the engine & belt - all of those necessitate a tensioner.
Be thankful the mini does not need a tensioner. They normally cost a LOT more than the belt.
PostPosted: Thu Mar 07, 2013 4:28 pm
The gates part numbers are very logical the part number you want should be X195L075 where X is the material kevlar or otherwise L is the tooth shape and the numbers should be length and width. IIRC
Gates are an OEM supplier so unless you have an engineering degree they wont give you the time of day. It was probably easier to say not available than risk a verbal contract for a part that they haven't extensively tested in a particular scenario. in this case a mini.
Better yet get the part number of the belt you bought from minimania next time you have accses to it. All gates part numbers are printed on top of thier belts.
PostPosted: Thu Mar 07, 2013 6:00 pm
I gave them the part number and showed them the Gates kevlar belt. Actually it was their local distributor in Kings Park, not Gates direct.
3 weeks later they just said nope, it was not available.
They are made by Gates in Japan, only for MiniMania in US, if I want any Gates ones that's where ya get em apparently. :cry:
[edit] typos
Last edited by drmini in aust on Fri Mar 08, 2013 6:10 pm, edited 1 time in total.
PostPosted: Thu Mar 07, 2013 6:16 pm
That part number I provided brings up thousands of suppliers so the made especially for mini mania sounds a bit sus.
PostPosted: Thu Mar 07, 2013 8:10 pm
Google says
"Your search - X195L075 - did not match any documents.
Suggestions:
Make sure all words are spelled correctly.
Try different keywords.
Try more general keywords".
PostPosted: Fri Mar 08, 2013 4:52 pm
Belts are funny things...
In the US Honda Civic belts last 100K miles.... in Oz they wear out in 100K kilometres.... Old style Volvo belts are lifed at 100K .. but my last one was still alive at around 450K (Volvos have non-interference engines :).
I've run belts in my Minis for the 25 odd years... initially Pirelli now Gates. I generally change them whenever there's some reason to pull the engine. I have never had a belt come out that looked anything but pristine...
These days they're not quite as cheap as they used to be so this time I have left the current MM belt alone.. We'll see
Cheers, Ian
PostPosted: Fri Mar 08, 2013 6:13 pm
Cheers, Ian
Fiat 124AC & 125A belts (also were Pirelli) are lifed at 80,000 miles, they go BANG (lose teeth) @ 100,000 miles. As I found out. It took out 7 valves and 7 valve guides... the pistons were all fine.
[edit] Nobody knows how long a Dayco/Pirelli Mini timing belt lasts, the belt makers don't tell you, and being made in Italy, these Triger belt drive kits were not a production fitted part (unless Innos ever got them, which I dunno) so BMC/BL/Rover can't tell you either.
As I said before, I changed one at 40,000 miles and it looked perfect. I have another Dayco that's done 25,000 and looks the same.
 Post subject: Timing belt
PostPosted: Sat Mar 09, 2013 4:13 pm
I just got 2 over in my order from minispares and they are Dayco ISORAN,made in EEC. They are a stock line for them!
PostPosted: Sat Mar 09, 2013 4:32 pm
Its interesting that the world has turned and new cars have gone back to chains...
They're much better designed these days I am told.
PostPosted: Mon Mar 11, 2013 8:52 am
Apart from the early GM Alloytec V6 in which the chain was under-designed. I think newer motors are OK though.
PostPosted: Mon Mar 11, 2013 2:56 pm
Google says
Suggestions:
Try this
X is a variable or place holder replace it with what you want the belt made of as I said in my post.
