It is currently Thu Jul 24, 2025 6:25 am
 Post subject: mini rebuild
PostPosted: Fri Feb 22, 2013 11:02 am
This is going to be our rebuild thread.
At present I am confused.
We (daughter & I) purchased a "rust free" round nose body and bits, firewall #23890 (which Morris 1100 tells me is 1967-thanks).
photos here http://s1119.beta.photobucket.com/user/effpeetee/library/mini23890
I have discovered whilst fixing up the rust and stripping paint and bog off that the front panel and both front mudguards have been replaced and signs of accident damage to front inside panels. Thats OK. But what is confusing me is that the rear lights are a welded in rectangular section. It looks as if it is a clubman rear section with roundy tail lights welded in. There is also a welded in plate covering up a drivers side fuel filler hole. I can see no sign that the rear panels have ever been replaced.
Is this normal?
Roundy Sedan project with/for daughter
PostPosted: Fri Feb 22, 2013 11:13 am
When the Clubby came out in 1971, it was trendy back then to fit Clubby tail lights.
And RH tanks have always been popular to add if big motors are fitted.
If it is a 67 the wipers should park on the driver's side, and the scuttle top panel should be flat, not dished in where the wiper shafts are.
PostPosted: Fri Feb 22, 2013 4:12 pm
When the Clubby came out in 1971, it was trendy back then to fit Clubby tail lights.<snip>
Other way round in this case, isn't it? Emulating the look of a Mk 1 in a Mk 2/3/4.
 Post subject: Re: mini rebuild
PostPosted: Fri Feb 22, 2013 4:45 pm
http://www.minisport.com.au/prod1276.htm
PostPosted: Fri Feb 22, 2013 4:47 pm
No, he is emulating the look of a Mk1 on a Mk1.
PostPosted: Fri Feb 22, 2013 6:21 pm
I'd say someone put Clubby lights in it, then someone else thought that looked shizenhausen, and converted back to Mk1 lights with the insert panels you can get.
PostPosted: Sun Feb 24, 2013 11:07 pm
Thanks for making our confusion less confused. So we do still have a Mk1 it is good to know.
Today we finished stripping all the paint and bog off it.
Should I weld up this hole above the drivers side rear light or is it for something?
thanks
frank
PostPosted: Mon Feb 25, 2013 12:09 am
weld it up. its not meant to be there
- '74 Clubman Ute project
PostPosted: Mon Feb 25, 2013 9:22 am
I have to admit I put Clubby tail lights in my 69 MK 2 back in 1971 :oops:
1970 Mk 2 Cooper S
PostPosted: Thu Feb 28, 2013 8:06 pm
Just finished stripping the engine bay paint.
Is the number on the top of the radiator vent cowl meant to match the body number?
This car has (i think) 112 above 05 and then the number 23403.
thanks
frank
PostPosted: Thu Feb 28, 2013 9:05 pm
Nope it's around 500 different. Give or take a bit.
[edit] That prefix is M2 05 I think.
PostPosted: Wed Mar 06, 2013 2:44 pm
another stupid newby question
are the studs on the front suspension towers removable/replaceable?
thanks
frank
PS: stripping the underseal off the underside is a pig of a job!
PostPosted: Wed Mar 06, 2013 2:48 pm
Yes the studs do come out but are often rusted in. WD40 or penetrene soak overnight followed by Mr LPG torch (or a good hot air gun) will free them up.
PostPosted: Sat Mar 09, 2013 11:00 pm
thanks drmini - got them out now.
there are two minis dumped on the farm
apart from the missing stuff I don't have is there any other parts that I should grab off them that is potentially going to be useful?
PostPosted: Sun Mar 10, 2013 12:16 am
Check the numbers on the head (somewhere between the valves or near the thermostat), block and gearboxes (behind the oil filter). The subframes and suspension components can be useful, wiper motors, check the numbers on the bodies mainly the straight one just to see what they actually are. The seat frames may be worth something but by the looks of it theirs not much more left on the shells.
From the looks of it the yellow/white one looks like an 850 so if the doors aren't too bad they could be worth some cash (good ones go for $200 each).
The red shell if it's not to rusty could be worth saving or selling aswell.
Users browsing this forum: Bing [Bot] and 102 guests
