It is currently Tue Aug 19, 2025 1:06 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jan 06, 2013 2:16 pm
Die Die Die!!
to be honest i know it will "chomp" the bolt so i didnt try too hard with the multigrips, and the pair i do have are smallish at $25 a pop its better value to just buy new studs
also one less thing persuading people not to buy the old engine and subframe im stealing them from.. :p
PostPosted: Sun Jan 06, 2013 2:55 pm
Oh yeah, no studs in the frame is a deal breaker! :lol:
PostPosted: Sun Jan 06, 2013 2:59 pm
I prefer bolts. They don't get bent when you drop the subby down a bit to replace the rack.
Mini King would have some if you want to go that way.
PostPosted: Mon Mar 11, 2013 11:14 am
Die Die Die!!
so studs/bolts are interchangeable ? i can buy some bolts instead of fitting studs ?
http://www.minispares.com/product/Class ... .aspx|Back to
PostPosted: Mon Mar 11, 2013 1:11 pm
Yes, you should be able to use these ones on a dry subby. Hydro ones are different so they say there (see link), but my hydro bolts looked same as these ones.
PostPosted: Tue Mar 12, 2013 6:25 pm
Die Die Die!!
which goes on the front and which the rear of the rear subframe ?
Users browsing this forum: Bing [Bot] and 292 guests
