It is currently Mon Jul 21, 2025 4:05 pm
PostPosted: Mon Mar 18, 2013 8:31 am
Hi,
I am attempting to fit new rubber cross unis to the Shitbox Rally Van.
I popped off the top balljoint to get them into position, but I'm struggling to get the u-bolts slid home.
Any tips from someone who has done this job recently?
Thanks,
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Mar 18, 2013 8:36 am
probably need to bend the u-bolts "in" a bit
they often spread while in use
Oh!!! & don`t over tighten them
& also i`d be setting the car up with the axles in their "in-use" height,,, so rest the car onto it`s wheels before you try to tighten the u-bolt nuts
PostPosted: Mon Mar 18, 2013 4:37 pm
good advice matt :D
First you get the money,then you get the power,then you get the Mini.
PostPosted: Mon Mar 18, 2013 6:09 pm
+1 for Matty's advice,
Also... new or old bolts? I've found some new bolts seriously wrong (far too wide)... so in went the old bolts with the new nuts :)
Oh... and... DON'T OVERTIGHTEN THEM!
sorry, just had to emphasise that point :mrgreen:
cheers,
Jacob
PostPosted: Mon Mar 18, 2013 6:40 pm
Just squeeze them up in a vice till they fit neatly/easily, check them in the yoke before trying to fit the joint.
Brian
PostPosted: Mon Mar 18, 2013 6:57 pm
Online
A viable alternative to the rubber joints is the QL5000 conversion, which uses a conventional Triumph TR6 Hardy Spicer joint with needle bearings, fitted with 4 nylon cups.
However I have it on good authority from a local distributor this week that Quinton Hazell in the UK (who supplied them) have recently gone broke and are in receivership. :cry:
If this is correct it will be a pity, they made & supplied quite a lot of Mini replacement parts.
[edit] see http://www.bbc.co.uk/news/uk-wales-nort ... s-21360719
PostPosted: Mon Mar 18, 2013 7:52 pm
Thanks guys, will give them a squeeze. Like a lot of things on this car, the original u-bolts were missing, so we are working with the new ones in the kit.
I have a set of the QL5000 conversion parts, but they are reserved for my Traveller. Watto and I agree they are not necessary for the Shitbox.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Mar 18, 2013 7:54 pm
Those QL5000 joints are heading towards Rocking Horse Poo material. I tried recently to find two new ones world wide with no luck. I got given one second hand and brought the a new joint with second hand cups. which wasn't cheap.
I my have to convert the next box I do to a hardie spicer set up as i have a couple of sets but only if I can find some side covers.
PostPosted: Mon Mar 18, 2013 8:00 pm
The Mini King
cheers,
Jacob
The original New old stock U bolts are still avail From Mini King
PostPosted: Mon Mar 18, 2013 8:03 pm
John, do you have those plastic posts that go between the van tank and the body?
We need some of them quite urgently!
Thanks,
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Mar 18, 2013 8:06 pm
The Mini King
Thanks,
Yes I have both types in stock , Send Me a PM if You Like
Regards
John
PostPosted: Mon Mar 18, 2013 8:20 pm
PM sent John.
Brett.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Mar 19, 2013 5:06 pm
Problem solved the easy way.
Watto fitted the Unis today while I was at work!
8)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Mar 19, 2013 6:06 pm
Online
PM sent.
I can modify `meaty' Oz std sidecovers into Cooper S ones. I did some last year for Mini King.
PostPosted: Tue Mar 19, 2013 6:57 pm
PM sent.
yes there are 2 castings for these,,, some are thicker around the seal & bush area & those are the ones that can be machined out to fit the bigger bush & seal into
ya cant really miss them when you have a look,,, we have quite a few thick ones here Doc , if you ever need some more,,, both the early type & the roddy type
Users browsing this forum: drmini in aust, Steam, timmy201 and 93 guests
