It is currently Tue Aug 12, 2025 5:57 am
PostPosted: Sat Apr 13, 2013 9:26 pm
Hi guys, I've been trying to fit some retractable seat belts in to the front of my mini but the ones that i bought don't seem to line up with anything. Now the description when i bought them said they will bolt straight in to the existing holes with ease but no they won't. Mini front inertia real, retractable seatbelt.
I bought these ones here,
http://www.minisport.com.au/prod775.htm
Has any one fitted these befor and is there a trick to it that im not getting?
Please help me haha
Regards
Regards Kermit (TadPole)
PostPosted: Sat Apr 13, 2013 9:32 pm
Standard Klippan setup - most minis have those these days.
Whats the issue? the pivot goes at the top the inertia reel goes into the doorbin (clubby) or under the door (roundy) and the other end goes under the door too.
PostPosted: Sat Apr 13, 2013 9:33 pm
Please help me haha
Regards
Do you mean the bolts don't thread into the threaded holes in the body, or you just cant work out how it should fit together.
PostPosted: Sat Apr 13, 2013 9:38 pm
Well if i put them below the door, it hits the door pocket when i close the door, plus the seat belt clip would be on the wrong side, If i do it the way the clubbys are and put the reel in the bin and the other end under the door i get the same problem. Does any one have any pics of how they have done it ?
PostPosted: Sat Apr 13, 2013 9:39 pm
Should look like this at the bottom on a roundy. Note the bracket tilts forward to clear the door.
Bolting it in isn't a problem. It's just nothing works together
PostPosted: Sat Apr 13, 2013 9:40 pm
May need to shorten the bracket under the door and put another hole in it - but its normally done without. The above is how most minis are.
Reel goes into the bin where it should be in a clubby.
My pics are useless to you - got rid of the door bin instead! :lol:
Thanks for the pics, so it should be tilted forward to clear the door bin?
PostPosted: Sat Apr 13, 2013 9:42 pm
Lol some one else suggested that in my family who was trying to help me, But I wanna keep them on there. I don't think that it would pass compliance if i was to cut them?
Yes. Thats the angle it gets pulled when it is worn anyway.
PostPosted: Sat Apr 13, 2013 9:43 pm
Ok thanks very much for the help, I'll go give that a go :)
PostPosted: Sat Apr 13, 2013 9:50 pm
Once it is all in another thing you may notice that happens is that when the door gets closed it may cause the belt to lock because the door pocket gives the belt a little tug meaning you have to wiggle it up a little to unlock it. I found after 6 months or so it happens less as the return spring gets a little weaker.
PostPosted: Sat Apr 13, 2013 11:31 pm
Put them in now and working fantastically, thanks for the help. Much appreciated :)
