It is currently Mon Jul 28, 2025 8:51 pm
PostPosted: Sun Apr 21, 2013 2:12 pm
I have just started cleaning the engine bay out and noticed the front panel and welded subframe mounting brackets are in a bad way. There is rust in the mounting plate and the areas where it attaches to the front panel
If i purchased a new front panel, does anyone know if they come with the subframe mounting brackets attached to the new part?
Any suggestions on repairing or replacing this section would be helpful
PostPosted: Sun Apr 21, 2013 4:54 pm
They do come with the front subframe mounts welded in place. If you could add some pics of your rusty panels that would help us give you more accurate suggestions.
PostPosted: Sun Apr 21, 2013 6:27 pm
I hope this works, this is the subframe mounting bracket
PostPosted: Sun Apr 21, 2013 9:35 pm
It might be a bit to much to repair from scratch, unless you have some good panel and welding skills. Might be an option to find a secondhand replacement section from another mini that's well past it's usable life.
Is the passenger side the same (rusty) and is the rest of the apron in decent condition or what?
PostPosted: Sun Apr 21, 2013 9:45 pm
the other side is not as bad but still does not look good, the bottom of the panel is slightly bent up!
Im thinking of buying a new one from UK, unless someone has one they dont want on here. From what i can see it does not seem to hard to replace the whole panel (Hopefully)
PostPosted: Sun Apr 21, 2013 9:51 pm
You can buy from Australian suppliers (save $$$ on freight) or put up a wanted add in the "wanted" section, someone might have the panels you need.
PostPosted: Sun Apr 21, 2013 9:53 pm
can you suggest some suppliers here, i have looked at one in SA and they are about $390 for the panel without freight
PostPosted: Sun Apr 21, 2013 10:29 pm
Give Karcraft or Miniking in Sydney a call
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Apr 22, 2013 2:30 pm
another question about the front panel.... are parts aam1022 and czh563 the same?
One states pre 76 and the other is post 76 where the subframe rubber mounted on.... there seems to be various opinions on the net if the later will also fit a non rubber mounted subframe
Karcraft have the later and seem to believe it will fit the earlier subframe but just want some reassurance before i go ahead and order it
PostPosted: Mon Apr 22, 2013 2:38 pm
You need the pre 76 type front panel if you have an Aus made Mini. To fit the UK post 76 spec front panel requires Mods to either your subframe or the new panel.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Apr 22, 2013 2:44 pm
why is it so confusing for a novice!!
so i presume part CZH563 is the one
http://www.minispares.com/product/Class ... .aspx|Back to shop
Its a shame because i can get the other one in Aust but was concerned it would not fit
PostPosted: Mon Apr 22, 2013 5:26 pm
The Mini King
The AAM1022 Will Fit It just needs to have the 21A2624 mounts Fitted
No mods Req
PostPosted: Mon Apr 22, 2013 6:01 pm
No mods Req
Is that a solid mount conversion part?
I though the only way to use this front panel was to weld in a washer to reduce the hole back to "early" size.
Live and Learn. :)
Regards,
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Apr 22, 2013 6:43 pm
The Mini King
bnicho wrote:
No mods Req
Live and Learn. :)
Regards,
No If You weld a Washer on the panel You still have a gap between panel and subframe.
If you use the 21A2624 it is metal and Rubber and fills gap between the grille
Panel and subframe, The 21A2624 is the same Mount used on the Rover Mini,
You can buy solid mounts for the grille Panel However for this area of the car
I do not think there is a need
Regards
John
