It is currently Sat Aug 09, 2025 3:39 pm
 Post subject: Rocker adjustment screws
PostPosted: Sat Apr 27, 2013 10:35 pm
Hi all,
Just a quick one, adjusted the roller rockers today and the adjuster screws are screwed nearly all the way into the rocker...i.e. most of it is sticking out of the bottom. Is this an issue? Still had enough screw to tighten the retaining nuts, but only just!!
PostPosted: Sun Apr 28, 2013 7:27 pm
Small or big bore? Is it happening to just one or all of them?
Do you have spacers under the rocker posts? If you do, you may need to remove the spacers which will give you correct height (or visa versa, can't remember to be honest).
The correct angle of the rockers should be slightly raised on the valve end when the valve is closed. From what it sounds, it's far too low at the front and when fully open may be passed the correct angle where the roller is no longer centred on the valve tip, esp if you have a high lift cam.
PostPosted: Sun Apr 28, 2013 7:34 pm
It's a big bore and the rockers are 1.5 high lift roller rockers. No spacers fitted. has me (once again) stumped. can't see any other way of adjusting the rockers without machining a bit off the posts...
PostPosted: Sun Apr 28, 2013 8:49 pm
What brand are the rockers...?
Some have more adjustment than others.
PostPosted: Sun Apr 28, 2013 9:24 pm
they're minispares 1.5 high lift roller rockers!
PostPosted: Sun Apr 28, 2013 10:20 pm
I'd say your cam has been reground by a lot, which has reduced its base circle diameter & dropped the pushrods lower.
To get more threads, decking the head a bit more would help.
PostPosted: Sun Apr 28, 2013 11:07 pm
the cam is also new though, did they make different length pushrods?
PostPosted: Mon Apr 29, 2013 8:07 am
There are 2 lengths: 850-998-1098, and 1275 which are about 3/8" longer.
I doubt you have the short ones, in a 1275...
The Minispares 1.5 roller rockers have a standard size 5/16" adjuster screw as used on Cooper S forged, also the late A+ style sintered rockers (1976 on).
However the rockers & adjusters fitted are not made in UK now, perhaps they are slightly shorter than originals.
I recently swapped a full set out, because all 8 were bent from new. :evil:
PostPosted: Mon Apr 29, 2013 10:04 am
If your pushrods are too short they will almost hit the hole in the head itself?
Post some pics of it, that might help
EDIT: here's what mine looked like with 1.3's . Take note of the angle of the rockers when closed. If yours is pointing too far down at the front (or up for that matter) then something is not right and it may foul either the head, the rocker cover or both
PostPosted: Mon Apr 29, 2013 4:09 pm
Lillee those are Minisport ones- do you have a pic of the Minispares 1.5s you have on it now?
PostPosted: Mon Apr 29, 2013 4:22 pm
I do but they aren't static images. Looks exactly the same angle wise... except purple
PostPosted: Mon Apr 29, 2013 4:25 pm
OK I was just checking the adjuster spare thread length, seems plenty on yours.
Maybe he does have smallbore pushrods in it then... :?
PostPosted: Mon Apr 29, 2013 4:41 pm
Quite possible. PM me I have a whole brand new set of 1275 pushrods if you need some
PostPosted: Tue Apr 30, 2013 8:11 pm
thanks for all the reply's! Turns out the engine had the wrong pushrods!
Thanks for the offer but managed to source some before I saw your message!
PostPosted: Tue Apr 30, 2013 9:30 pm
glad you sorted it out!
