It is currently Tue Jun 24, 2025 2:35 pm
 Post subject: Clutch shudder
PostPosted: Mon Apr 29, 2013 8:16 pm
Wat causes the clutch to shudder .. Is it a flywheel problem or clutch / adjustment
PostPosted: Mon Apr 29, 2013 8:29 pm
Can be many causes- here's a few:
Loose engine mounts or steadies,
worn or badly machined flywheel or backplate surfaces,
`cornflakes packet' ie Asian made clutch facings,
oil on clutch plate,
worn thrust plate on diaphragm (recent ones are NOT hardened, & they wear bad with the late type release bearing),
worn `wok' bore & throwout plunger (rare).
PostPosted: Mon Apr 29, 2013 8:59 pm
Ok must be the flywheel as it has had a lot machined off it will talk to the engine builder c wat he thinks
PostPosted: Mon Apr 29, 2013 10:07 pm
When I say `worn or badly machined', I mean inside the flywheel where the clutch plate runs, not the outside bit that gets machined off to lighten it. :wink:
PostPosted: Tue Apr 30, 2013 6:28 pm
Also look to see if the flywheel is tight on the taper.
I had similar problem in the Moke after changing the clutch and i had to redo it all and lap in the flywheel and the problem went away
Kiwiinwgtn
PostPosted: Tue Apr 30, 2013 7:00 pm
What about the nose of the crank Doc...(the taper and how it mates to the flywheel) :idea:
and post height...
PostPosted: Tue Apr 30, 2013 7:11 pm
Incorrect post height (ie diaphragm spring not flat) can make it slip, but not shudder (unless say 1 backplate bolt has backed out a bit. I Loctite these bolts to be sure...)
Read this, it has lots of correct Mini clutch setup info:
http://www.minimania.com/article/153/Cl ... non-Verto_
PostPosted: Tue Apr 30, 2013 8:31 pm
yeah sometimes the whole clutch assy hasn`t been "set-up" properly on the flywheel & isn`t central (setting up the guts of it with the 3 straps)
so the tin-hat sits slightly off to one side & hey presto it shudders,,,
you`ll see the spring seat mark on the flywheel (where the spring has been pivoting on the flywheel) & it will be offset, not the same thickness shiny mark all the way around & may even be a ridge where it`s buried deep into the surface on one side & sitting off the ring on the other
have a close look when it`s all out & you`ll see
PostPosted: Tue Apr 30, 2013 8:43 pm
Would reducing the height of the back plate post as noted in the article help with clutch engagement
PostPosted: Tue Apr 30, 2013 8:58 pm
It definitely bites better on takeup when the diaphragm is set flat on assembly.
I have had some folks' clutches that needed .070" off the 3 posts to make it sit flat. In one case of a 1275LS like this, the clutch was slipping, but when removed the driven plate only had .020" total wear on it.
A new plate and machine the lugs, then it was all good again.
