It is currently Sun Jul 27, 2025 7:58 pm
PostPosted: Wed Apr 24, 2013 11:34 pm
nixphotopix wrote:
Can anyone recommend a reputable mini mechanic to look it over in Melbourne CBD? Any thoughts on what the problem can be?
take a drive out to Link in Mitcham
http://www.linkautomotive.com.au/
PostPosted: Wed Apr 24, 2013 11:48 pm
3400 rpm is a much easier issue to sort than being speed related. It'll be an electrical gremlin or vacuum line problem.
Here's the DIY ones:
-Check the hoses from the trottle body running into the metal pipe behind the rocker cover, and the two hoses off that into engine breathers. Replace hoses that have split or have holes.
-Theres a vacuum line running from the back of the throttle body to a small black box, then another vacuum line to the engine computer. The plastic plugs on these commonly crack / split / fall off. Check all of these.
If it isn't any of those it may be time to replace some sensors. Air temperature inlet and water temperature are the cheapest sensors and easiest to replace. The crank one is working, and the car barely runs if the TPS has gone, so shouldn't be them.
PostPosted: Thu Apr 25, 2013 4:07 pm
I second Simons recommendation for Link Automotive. What Brian doesn't know about minis isn't worth knowing. Brian won't waste your time or your money, heck I drive from Frankston South if I want something done that I couldn't do myself.
PostPosted: Mon Apr 29, 2013 9:07 pm
ill take the car to link this weekend, get them to check it out. Might as well get a full service while im there. Will let you guys know how it goes.
PostPosted: Mon May 13, 2013 11:37 am
Oh crap! Might have a real problem!
PostPosted: Mon May 13, 2013 11:38 am
And that would be what?
PostPosted: Mon May 13, 2013 12:02 pm
Dropped car into link. Possible big end bearing problem requiring engine out! Def didnt want to hear that. Just sold our second car this weekend also. Now gotta crawl car home and tell the wife.
PostPosted: Mon May 13, 2013 12:10 pm
Well that's a royal PITA.
Good luck getting it all sorted!
PostPosted: Mon May 13, 2013 1:26 pm
Yup, thrown into the deep end :cry:
They are fully booked out for next couple weeks so need to decide where to go from here. I only wanna do this once so any thoughts on what to do from here, and has anyone had similar exeriances with this prob? Link say it maybe anywhere up to $4000 and only a semi recon motor :?
PostPosted: Mon May 13, 2013 1:29 pm
Should I be purchasing necessary parts from the uk that will bring the cost down? Gaskets, water pump, bearings, etc etc?
PostPosted: Mon May 13, 2013 1:36 pm
Mine did something similar and I had the whole lot rebuilt - no point doing half the job.
If I remember tonight I'll put together a list of stuff for you that was done / bought.
PostPosted: Mon May 13, 2013 1:47 pm
Thanks Harley. Thats very kind of you mate. I brought a mini knowing I might have problems at some point, but nothing so soon or severe :oops:
Lucky my wife and I are both within walking/biking distance from work. Just sucks its coming up to winter which makes biking a lil more fun.
PostPosted: Mon May 13, 2013 2:14 pm
Each to their own - personally I'd ride to work before I get the mini wet! :lol:
PostPosted: Mon May 13, 2013 7:56 pm
could plonk this in
http://www.minimakeovers1275.com/mini-p ... id=4610819
PostPosted: Mon May 13, 2013 8:09 pm
you get what you pay for...Thats all i'll say (from experience :wink: )
Users browsing this forum: Bing [Bot] and 94 guests
