It is currently Thu Jul 24, 2025 10:04 am
 Post subject: Camshaft woe's
PostPosted: Sun May 19, 2013 10:25 am
I went to put the camshaft sprocket on and it fell on measured it up and it was 10 thou under size on the shaft is there a fix or is it a throw away my engine recon man sent it away to be re profiled to different grind while he was doing all the block work I'm sure it was ok when I sent it there but honestly I can't remember .I do have a lathe if I need to do any machining
PostPosted: Sun May 19, 2013 10:44 am
Is it a new sprocket? I saw a batch that had come in from overseas a few weeks back that had various dimensional errors. Thankfully the reseller sent them back...
It is unusual that a camshaft would be undersize where the sprocket fits on.. :?
PostPosted: Sun May 19, 2013 11:22 am
Nah is the shaft 3 original sprockets tried, problem shaft measures about 22mm the cooper s one I measured about 22.22mm in I'll re- measure later and re-post
PostPosted: Sun May 19, 2013 11:27 am
bum! was it the cam that came out of the engine?
the grinder may have cleaned it up?
PostPosted: Sun May 19, 2013 11:29 am
Yeah it was I just hope it never got swapped somewhere
PostPosted: Sun May 19, 2013 11:34 am
go back to the grinder and explain...
I don't think it'd be a good idea to try to machine up an adapter/spacer - it may work, but I reckon you'd constantly be worried about it and every time there was a weird noise you'd think the pulley was falling off
it wouldn't be unusual for it to have been swapped - the original may have not had enough material to take the new grind or he might have had one already ground on the shelf
PostPosted: Sun May 19, 2013 3:13 pm
Just measured it .864" cooper s one .874" I'm thinking it may need to be metal sprayed or thrown in the bin
PostPosted: Sun May 19, 2013 3:26 pm
I would ask the grinder first, sounds like he accidentally swapped you a dud cam for your good one...
