It is currently Thu Jul 10, 2025 8:26 am
PostPosted: Sun Jun 30, 2013 5:09 pm
Hi all,
Anyone know or recommend a good aluminium welder?
I have a gearbox case that has been welded prior near sump plug and it was a little rough and leaked a little so I would like to have it redone.
Thanks
100% Pure A Series Turbo
PostPosted: Sun Jun 30, 2013 5:20 pm
Mini gearbox casings can be difficult to weld, but devcon works a treat, just grind back along the affected area and apply! Have seen an engine block repaired with this stuff on a race mini engine, and it lasted years.
PostPosted: Sun Jun 30, 2013 8:37 pm
Boostedmini wrote:
Hi all,
Thanks
Do you need a replacement case? I have several you can take a look at?
Lillee - 1969 Morris Mini K
PostPosted: Sun Jun 30, 2013 8:46 pm
Graham has a nice tig that might do the job, but as said they are soaked in oil so can be difficult to weld.
but yeah graham did repair a crack on the back of mine that has held up well. :)
PostPosted: Sun Jun 30, 2013 9:10 pm
Graham is your man, he did a 1935 Alvis cast alloy gearbox part for me a few weeks ago. :wink:
It was oily too, I first had to cook it on the BBQ in boiling water and detergent and scrub it with a SS brush to get the 80 year old oil out.
PostPosted: Tue Jul 02, 2013 7:35 am
Graham Who :?: :? :?
PostPosted: Tue Jul 02, 2013 8:07 am
He only has one name, he only needs one name.
Just think Beyonce, Kylie, Oprah, Elvis and then try to get that image out of your head! :lol:
PostPosted: Tue Jul 02, 2013 8:10 am
I've had 4 cases repaired in the last couple of years by welding up the sump plug hole entirely where it was either stripped, cracked or the repair was dodgy and leaked. Local aluminium welding specialist Norweld in Cairns did them. Oil soaking wasn't mentioned as a problem. I do put them thru the hot tank at the engine shop though.
Then have my friendly machinist cut a new sump plug thread (5/8" UNC) and face the outside of the case square to the thread so no more leaks.
Steve
PostPosted: Tue Jul 02, 2013 8:19 am
All Good and fine but Who the hell are they talking about :?: :?:
PostPosted: Tue Jul 02, 2013 8:39 am
Be Graham Russell Dave.
Steve
PostPosted: Tue Jul 02, 2013 8:55 am
Well you got 1 out of 4, Beyonce is the only one of these that only uses the 1 name, the others all use/used 2.
Some other examples that you might have used are Prince, Madonna and Pink
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue Jul 02, 2013 9:26 am
Steve,
You forgot Abigail, Sting, Seal, Adele and Your Good Self "Cappa"
And Now Graham :lol: :roll: LOL
PostPosted: Tue Jul 02, 2013 9:49 am
not to mention twiggy, pele, jewel, stig, jordan, kamahl, jimeoin, barbie and ken
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Tue Jul 02, 2013 10:44 am
Neat job too - thanks to both BBQ boys 8)
PostPosted: Tue Jul 02, 2013 10:56 am
anyone considered God???
1962 Mini Speed sports sedan
