It is currently Fri Aug 22, 2025 6:28 pm
PostPosted: Thu Jul 25, 2013 8:56 pm
Die Die Die!!
will a Moke with no rollbar pass an inspection at a motor registry?
Edit - a 1982 moke
PostPosted: Thu Jul 25, 2013 9:02 pm
Yes.
It's not a rollbar. It's a 3 point seatbelt mount. If you have lap belts you're all good.
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Thu Jul 25, 2013 9:20 pm
Is it legal to only have lap belts in a 1982 car?
PostPosted: Thu Jul 25, 2013 9:48 pm
Yes, if that is how it left the factory - like most non-Californians!
PostPosted: Fri Jul 26, 2013 12:20 pm
PDJ wrote:
Yes.
It's not a rollbar. It's a 3 point seatbelt mount...
Why do people always say that?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jul 26, 2013 7:15 pm
I guess because that's what it officially was, a way to mount the seat belts and was never designed as a crash/rollover device.... :?
PostPosted: Fri Jul 26, 2013 7:31 pm
Wrong.
The car has a set of ADRs which relate to it, and it is illegal to decrease the standard of safety of a vehicle - seatbelts included.
PostPosted: Fri Jul 26, 2013 7:43 pm
willy wrote:
Wrong.
Your both right in theory.
If the car came from factory like that then it's still fine. But if the car orgionally had 3 point belts you can not change back to lap belts.
Best bet is to look up the ADR codes on the compliance plate, you have to comply with or better.
PostPosted: Fri Jul 26, 2013 8:50 pm
The Mini King
I am Reasonably sure That the Moke was Registered as a Comercial vechicle
and the ADR's were different to passenger cars, Hence it is rare to find Mokes
after 1978 that has a seating capacity of more than Two
PostPosted: Fri Jul 26, 2013 9:27 pm
I believe John is right - Mokes were registered as 2 seater commercial vehicles - two shells I have were ex-rentals from the central coast and have compliance plates certifying then as having been converted to 4 seater
Image[/URL]
David L
PostPosted: Fri Jul 26, 2013 10:13 pm
Leyland referred to it as a roll bar.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Jul 26, 2013 11:19 pm
willy wrote:
Wrong.
Right actually.
No one said anything about reducing the spec. Non-Cali mokes only had lap belts. In fact some Cali's did not have roll bars! They had compliance plates with lap belts and that is all that is required today.
Users browsing this forum: No registered users and 287 guests
