It is currently Thu Aug 14, 2025 1:33 am
PostPosted: Wed Jul 31, 2013 9:45 pm
captainwaldopepper wrote:
Hi Bill
I bought the clip-on one and some clips for my "68 deluxe and not only was it a bloody pain to fit, it leaked.
I ended up replacing it with the on-body type which was easy to fit and sealed better.
I guess it depends on whether you prefer originality over functionality.
Dave
Thanks dave , functionality works best for me .
I bought the original foam boot lid rubber, was a PITA to fit on with repro clips, so as a gesture to modernity I flung all those damned clips and used Selleys Kwikgrip contact adhesive. Looks OK and works fine.
Sounds the same as dave's problem so i will get the body one and some selly's kwickgrip :-).
Thanks again Dave & Doc
Cheers Bill
PostPosted: Wed Jul 31, 2013 10:04 pm
Be careful buying bootlid rubbers, some are too hard and need 3 people to shut the boot.
Here's what to look for-
http://www.minisport.com.au/prod505.htm
I think Mini King carries the soft one also, not sure about Kc and other suppliers.
PostPosted: Wed Jul 31, 2013 10:12 pm
They do get better with time, but it took about 9 months on mine to get better (Bootlid w/ clips type)
PostPosted: Wed Jul 31, 2013 10:26 pm
Thanks again Doc , Karcraft has a new soft design one in their catalog i will grab that one when i order the windscreen ones.
Cheers Bill
PostPosted: Thu Aug 01, 2013 7:37 am
There not so soft from karcraft i did mine last week need two people to close now and the clips are a pain to get in so that aldi double sided tape they had the other week worked well till i get more clips
PostPosted: Thu Aug 01, 2013 8:21 am
I found the soft one from Minisport SA (in my pic above) worked well.
PostPosted: Thu Aug 01, 2013 9:06 am
drjbeam there's a few in the karcraft catalog , did you get this one Boot Lid Seal Mini (on Boot Lid )NEW Soft Design 14A6584 <A> ? ...... if so i will go with the one Doc mentioned.
Cheers Bill
PostPosted: Thu Aug 01, 2013 9:38 am
Yep thats the only on boot lid type they have and id get 40 clips at 80 cents each i was quoted $1.90 each at another place in west sydney wasnt mini king
PostPosted: Thu Aug 01, 2013 10:03 am
Thanks for that , i will go the other one then .
Cheers Bill
Users browsing this forum: No registered users and 256 guests
