It is currently Tue Aug 12, 2025 5:13 am
PostPosted: Mon Oct 21, 2013 9:02 pm
( formerly the Rod change oil retention prevention system* thread)
I know you can get a kit to stop this badboy from leaking, but what is the name of the metal part in the picture?
I suspect this (and the pin) needs a replacement too.
Oh and hi.. :-)
PostPosted: Mon Oct 21, 2013 9:41 pm
42H1116 is its partnumber, called coupling or eye bold sleeve
Rover 214 atm ....
PostPosted: Mon Oct 21, 2013 10:07 pm
I would call that f#*cked.... wow never seen one that bad. How did you get gears
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Oct 21, 2013 11:09 pm
Wrong Cush! You can buy a kit to slow that thing's leak. You cannot buy a kit to "stop" that thing from leaking.
M
Oh, and welcome back again.
PostPosted: Tue Oct 22, 2013 7:07 am
i make new "Seal-bushes" for them Cush
& yes these new ones are removable to enable the replacement of the inner oring :-)
& yes welcome back young fella :-)
N.B. Image display fixed - winabbey
PostPosted: Tue Oct 22, 2013 7:22 am
How might they work? Where to they fit..?
What's it meant to look like? :-)
Sent from my Nexus 7 using Tapatalk
PostPosted: Tue Oct 22, 2013 1:29 pm
New couplings made in Oz and case hardened are available now from Mini King.
PostPosted: Tue Oct 22, 2013 5:45 pm
I'll have one of Matt's and one of the doc's...
PostPosted: Tue Oct 22, 2013 5:55 pm
You can always grab 1 of these aswell
ROD CHANGE OIL SEAL ENHANCEMENT KIT
Cheers Bill
PostPosted: Tue Oct 22, 2013 5:56 pm
Frooooooooooooooomm..
PostPosted: Tue Oct 22, 2013 6:00 pm
Ooops my bad ..... ebay
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1299291152
Cheers Bill
PostPosted: Tue Oct 22, 2013 6:11 pm
I thought I knew that logo.. It's wood and Pickett.
Now I know.. I might even change the subject...
PostPosted: Tue Oct 22, 2013 6:12 pm
Personally i think Matt's seal is much better then that ebay one. Just knock it in first and then a plain old oil seal and it shouldn't leak again.
PostPosted: Tue Oct 22, 2013 6:22 pm
You crazy Matthews must stick together...
http://minisport.com.au/prod593.htm
I'm assuming Matt (Read) your bit replaces the metal part of the above kit?
PostPosted: Tue Oct 22, 2013 6:41 pm
It does. And it works.
I got a couple of these off Matt about 6 or 7 years ago, still going strong.
You need to use an ordinary seal too. The hard part is getting all the old ones out.
Users browsing this forum: No registered users and 260 guests
