loveb wrote:
yeah, i might drive around the block and re bleed using the stick tomorrow... stick on - undo - redo stick off - stick on - undo - redo lol
also, i know this is on a minor forum, but it does possibly make sense i think?
http://www.morrisminorforum.com/article ... eding.htmlYes that can be useful when the going gets really rough, but it seems to be working itself out now.
I find that because of the large amount of fluid which passes to the clutch slave cylinder, and the short distance, that air will generally be passed back to the MC over time to settle out by itself. A little bit more of a bleed will be all it needs now.
I told you about the old trick of putting a stick between the seat and the pedal overnight also helps. It squeezes the entrained air down to a couple of thousandths of its original size to help it detach and work its way up to the highest point in the cylinder a little more easily. Really good for brake systems I find. You've already done this though, and it is getting better as you have seen.
