It is currently Sun Jul 27, 2025 8:24 pm
 Post subject: eletric fuel pumps
PostPosted: Sat Jan 25, 2014 12:14 pm
Hi.
i have had a few dramas with the cheap electric fuel pumps and want some thing a little quieter and reliable. looking at the facet pumps what pressure should i be looking at getting? (im using twin su) do i need a regulator? there is quite a few types any to stay away from/ what would you recommend.
thanks
 Post subject: Re: eletric fuel pumps
PostPosted: Sat Jan 25, 2014 12:58 pm
the facets will still give you the familiar ticking. pressure about 3 psi. regulator - optional
PostPosted: Sat Jan 25, 2014 2:05 pm
Personally I dont think you can go past a genuine SU electric pump.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Jan 25, 2014 5:41 pm
I've had no probs with the square 3psi Facet ones, the one on my car has been there 20 yrs since I bought the car and it was s/h then.
I would not bother with a regulator unless using a higher pressure pump, and if you do, ffs fit a pressure gauge. Cheap regulators (some) have hopeless calibration.
PostPosted: Sat Jan 25, 2014 7:20 pm
thanks. this one here should be ok then? http://www.ebay.com.au/itm/FACET-FUEL-P ... 3a84e709c8
PostPosted: Sat Jan 25, 2014 8:30 pm
That one will only be good if your mini is 24 volts
PostPosted: Sat Jan 25, 2014 9:17 pm
Here are specs...http://www.facet-purolator.com/cube-fuel-pumps.php
PostPosted: Mon Jan 27, 2014 6:00 pm
Thats what i reckon as well , you can buy new parts for them from SU Midel , they are easy to repair ,
but more often than not , they just need a clean internally , they tend to gum up over time .
PostPosted: Mon Jan 27, 2014 7:56 pm
I sell Facet style fuel pumps which are suited for SU carbs. about 2.5 to 3 psi. I sell these for $50.00 posted. I also supply two rubber mounts with it for it FREE. these minimize the noise they make through the body.
Send me a message if you want one.
Tony.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Tue Jan 28, 2014 9:36 pm, edited 1 time in total.
PostPosted: Tue Jan 28, 2014 9:22 am
cheers guys.
Users browsing this forum: diecast and 85 guests
