It is currently Fri Jun 27, 2025 11:27 am
PostPosted: Sun Feb 02, 2014 10:46 am
Hey guys
Just wondering if someone could take some photos of the rear seat belt mounting points.
Im wanting to fit belts in the back of my deluxe for the kids.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Feb 02, 2014 11:04 am
I'm pretty sure deluxe's don't have rear seatbelt mounts, I'm sure I'll be corrected if wrong but you could just copy the later model mounts. I some states, big brother wants you to get them checked, if this is the case where you are, it's best to ask the certifier where they think they should go. It's a bit stupid but I'll use this sinario to explain.
You have an head on accident (not your fault) and your mates in the back fly out through the screen and get killed because you have no seat belts. You don't get charged with anything. Same sinario but you have fitted seat belts yourself and no certification. The mounts fail, you get charged with manslaughter. Certified ones, you don't, whether they fail or not.
See if you can see sense in that.
PostPosted: Sun Feb 02, 2014 11:10 am
Hey peter yeah im aware the deluxe has no rear belt mounting points. Im aftet some photos of later clubmans.
I do plan in getting them certified as it will be my children in the back.
Minis..
1975 van
PostPosted: Sun Feb 02, 2014 11:59 am
does the deluxe have the reinforced bit in boot
PostPosted: Sun Feb 02, 2014 12:04 pm
On the shelf or boot floor? Im guessing not since it never had seat belts. There is a new floor going in so hopefully that will have the mounting points in it already
Minis..
1975 van
PostPosted: Sun Feb 02, 2014 12:09 pm
I can put picture of Rover set up on if you like? Mine has enertia reels on parcel shelf. Enertia reels are probably better for kids, allows then movement but still secures them. do you have ER's in front?
PostPosted: Sun Feb 02, 2014 12:14 pm
Cheers I would appreciate some pics. Atm its a bare shell but will be putting inertia belts in it.
Minis..
1975 van
PostPosted: Sun Feb 02, 2014 12:20 pm
In the cubby box, like rover?
PostPosted: Sun Feb 02, 2014 12:27 pm
these are klippan seta belts
The 2 last pictures are at funny angles as it's hard to take pictures in boot. The 2nd last is underside of parcel shelf on D/S/R. The last is lower R/H belt mount, pict needs rotating 90 deg anti clockwise
PostPosted: Sun Feb 02, 2014 5:48 pm
I'm led to believe that you can buy the correct plates from a place in Blacktown Sydney , but i'm not sure as to how you would go with the engineering side of things .
Apparently they can supply & fit and sort the legal side of it , i'll see if i can find their buisness name .
PostPosted: Sun Feb 02, 2014 6:19 pm
Cheers goodie
Minis..
1975 van
PostPosted: Mon Feb 03, 2014 6:19 am
I'm still trying to find the name of the place in Blacktown , but these guys might be able to help you ,
can't hurt to ask , http://seatbeltsolutions.com.au/company/ .
PostPosted: Mon Feb 03, 2014 6:59 am
Little's Child Restraints. Sunnyholt Rd.
