It is currently Mon Jul 21, 2025 8:11 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: SU Verses Weber?
PostPosted: Thu Feb 06, 2014 3:24 pm
Or...What about this? The Mikuni option.
viewtopic.php?f=5&t=83289&hilit=mikuni
PostPosted: Thu Feb 06, 2014 3:48 pm
and... here's a comparison vid I just made :-)
Short-shifting on the last one as the car is yet to be tuned so I'm not revving the buttocks off it :P
As mentioned in previous posts, the last vid is not a direct comparison as the head work / cam make a big difference to the sound and performance. How good does it sound though!! hehehehe
http://www.flickr.com/photos/chux007/12337206304/
PostPosted: Thu Feb 06, 2014 7:30 pm
Listen to this video and then see if you can guess SU or Weber...
http://www.youtube.com/watch?v=rRNoRlLlsD8
PostPosted: Thu Feb 06, 2014 7:40 pm
As much I want to say we've it's got to be multiple SUs
Sent from my GT-I9210T using Tapatalk 2
PostPosted: Thu Feb 06, 2014 7:41 pm
Wrong.
Next guess?
Over 500hp from 1500cc.
PostPosted: Thu Feb 06, 2014 7:53 pm
Sounded like a two stage Rolls Royce centrifugal supercharger with twin 3" SUs to me.
PostPosted: Thu Feb 06, 2014 7:59 pm
I wouldn't call it twins, it was a single SU with two chambers.
Would you call a single Weber "twins"?
PostPosted: Fri Feb 07, 2014 4:25 pm
Most of the comparisons are between a 45mm sidedraft and the S/U's
But how does a 40mm sidedraft compare to the S/U options?
My mini came with a 40 dellorto (not fitted) and I am wondering how it will perform, or if I would be better with a 45?
PostPosted: Fri Feb 07, 2014 6:08 pm
A 40 Weber or Dellorto is fine on a near stock 1275 but if you are modding it for big numbers (or it's a 1360 or bigger) I'd go the 45DCOE instead. Or a Dellorto DHLA45.
PostPosted: Sat Feb 08, 2014 6:45 am
The Mini King
Road Car SU's every time, Race car maybe Weber
PostPosted: Sat Feb 08, 2014 8:19 am
IMO sidedraft Webers & Dellortos are easier to tune, IF you have an A/F ratio meter.
With an SU you are never sure that the needle you are using (out of the 700? available) is the optimum one. :wink:
[Waits for GR the SU man to jump on here and demolish my arguments..] :P
Noting that GR "beat" the great Keith Calver (Weber) using SUs 8)
PostPosted: Sat Feb 08, 2014 9:25 am
Was a while ago...
But GR's Nb racer runs a 45 Weber, as do most in the class, not SUs.
PostPosted: Sat Feb 08, 2014 9:37 am
my comparison was 2 x 1 1/4 SU's vs a 40 DCOE Weber :P
PostPosted: Sat Feb 08, 2014 10:19 am
SUs! But only because they look great..
PostPosted: Sat Feb 08, 2014 10:59 am
I've got a sidedraught Weber 45 on my 1310 Cooper S and HIF 44 SU on my 1360 van. Weber looks and sounds much better (better than many V8s even with Brownriggs and original Lukey style box), is more responsive and reasonably easy to tune and doesn't need any choke when starting from cold. The SU is up to the job but seems a bit more fussy than the Weber. My brother once had a downdraught Weber on his Mini, but that was not as good as an SU.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
Users browsing this forum: No registered users and 68 guests
