It is currently Fri Aug 22, 2025 9:57 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Feb 19, 2014 2:17 pm
When/did the English Minis ever move to stamping the engine number directly onto the block instead of the riveted tags?
I know in Australia you have to have the number stamped on the block directly, so maybe this one has been done at a later date, and suffered from a typo?
Edit:
This late injected engine has the tag riveted on the block? All the tags I've been able to find in photos have a different font to yours too, and have been stamped from underneath so that the numbers are imprinted upwards
Engine tag example (it's an older engine though)
http://www.ebay.co.uk/itm/Classic-mini- ... 417cf3079b
PostPosted: Wed Feb 19, 2014 4:48 pm
I believe late model Rover 1275 Mini's had their numbers lazer etched (1996 onwards)
PostPosted: Wed Feb 19, 2014 10:14 pm
I believe the work experience kid stuffed up the stamping in the factory...
PostPosted: Wed Feb 19, 2014 11:06 pm
John Sneddon wrote:
The best answer I can provide in accordance with Parts List AKM1217FR dated September 2001 which covers Rover Mini from 1990 on is:
12 - 1275cc
A - A series engine
2 - 8 valve configuration
A - carburetor specification
D - Throttle Body Injection, Base, 9.4:1
J33 - ???
There a number of "J" details relating to various engine/transmission configurations bu nothing like J33.
Sorry I can not be of more help
Cheers John,
Do you think the J33 could have anything to do with it possibly being a Japanese import?
PostPosted: Fri Feb 21, 2014 9:16 pm
Well the deal has been done I brought myself a 97' 1275 A+ with 77000kms on the clock. Everything you see in the photo (except the shovel and power cord!) plus a Weber 45 DCOE. I've just gotta get it to Perth now, strip it n fit it :D
PostPosted: Fri Feb 21, 2014 9:40 pm
How much did you pay if you dont mind me asking. Looks good too.
Will buy the weber of you ?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Feb 21, 2014 9:44 pm
I'll tell over a couple of beers sometime soon. I'll let you know about the Weber, I have twin SU's currently but I wouldn't mind running the Weber, no final decision made yet!
PostPosted: Fri Feb 21, 2014 10:12 pm
Yeah I have twins too. Always wanted a weber...
Minis..
1975 van
PostPosted: Fri Feb 21, 2014 10:17 pm
Do you even need to pull it down? We can run it as it sits there and make sure everything is ok
Minis..
1975 van
PostPosted: Fri Feb 21, 2014 10:41 pm
I wanted to get 1275 in the first place to strip and rebuild but with only 77000 kms on it I'm not sure if it needs it just yet! I don't want to bore it just for the sake of it as I want to try maximise its life. If it run ok might chuck it straight in and rebuild my 1100 as a kind of test run then do the 1275 in a few years!
PostPosted: Fri Feb 21, 2014 10:45 pm
Yeah looking at the pic. Everything looks clean and tidy. Not sure about the subframe bolts as I thought the rovers had 1 large mounting bolt. But I would say oull out your subframe complete and just drop this lot in.
Minis..
1975 van
PostPosted: Fri Feb 21, 2014 10:48 pm
Mind you that shovel looks pretty good too. I would have pushed a harder bargain. Your gonna need something to dig the grave when your missus finds out....
Minis..
1975 van
PostPosted: Fri Feb 21, 2014 10:50 pm
The guy I brought it off had it in a Moke so the subframe isn't a Rover one. He did all the hard work converting it to run on carbies and powder coated the subframe had all new steering, brake etc and then only covered 3000kms. Overall a pretty good deal (I'm just hoping it's not all too good to be true!).
PostPosted: Fri Feb 21, 2014 10:54 pm
Yeah sounds like a good deal. Looks really clean. Good stuff.
When does it arrive?
Minis..
1975 van
PostPosted: Fri Feb 21, 2014 10:56 pm
Mmmmmm..... How am I going to explain this one to the better half?
Users browsing this forum: No registered users and 243 guests
