It is currently Sun Jun 22, 2025 3:58 am
 Post subject: Re: Rod or remote
PostPosted: Tue Mar 25, 2014 9:33 pm
1071 S wrote:
The real question is..."are the rear diff casing from a Mini and 1100 the same? ie can you redrill an 1100 casing to suit a Mini remote shift??
Cheers, Ian
No. I don't think so but will have a look tomorrow.
But I fitted an 1100 diff casing to a Mini K box for Morris 1100, it's in his car with the infamous `scatter crank stroker' on top..
PostPosted: Tue Mar 25, 2014 10:00 pm
No.
Different amounts of metal in different places.
Different shapes.
But apart from that... :mrgreen:
PostPosted: Wed Mar 26, 2014 7:04 am
What gearbox is the strongest i've been told that remote are alot better to drive?
Present
- 1968 Morris Mini Deluxe- resto
-1979 Leyland Moke
-2007 R56 MINI Cooper
Past
-1964 Morris Mini Van
-1965 Morris Mini Van
-1961 Morris Mini 850
PostPosted: Wed Mar 26, 2014 7:21 am
Gears set in the common Oz rodchange box is the same as in a 4 synchro remote one (Mini-K) except reverse gear fork slot. So they are equal strength.
It's easy to put Mk2S ratios in these boxes, you just need an 18T 1st motion shaft (4th gear) and a 22G1040 cluster gear.
Both are stronger than the old 3 synchro magic wand or remote boxes. They were weakest on 1st gear if hammered, followed by 2nd gear.
Later rodchange box A+ etc has a 1/8" bigger idler gear shaft, an 18mm mainshaft nose bearing, and a bigger needle bearing in the 1st gear end of the cluster gear. So yeah it's a bit stronger. Not sure about gear ratios....
I like remotes, the shift is more precise, IMO. As long as linkage wear is eliminated by rebuilding or replacing worn parts. Some shift parts are now NLA but can be reclaimed by hardfacing.
PostPosted: Wed Mar 26, 2014 9:21 am
Mini mania have a late model gear cluster in a remote box, takes some machining work.
PostPosted: Sat Mar 29, 2014 10:49 pm
I remember seeing some new rod boxs at karcraft last year but something was different to the aus box tony said when i asked and they were already sold i think
