It is currently Sat Jul 19, 2025 5:41 am
 Post subject: SU Needle Help
PostPosted: Sat Apr 05, 2014 1:11 pm
Give Ash some flowers Nick .
Hey everyone,
Just after some advice on which way to go with needles in my mini.
Currently running GY and they were a bit lean mid range, have some borrowed Ms in there now and slightly better but still lean mid range (1800 - 2800rpm). It is fine just off of idle and from 3,000ish rpm up in both cases.
I have narrowed it down to DU, L or EQ with I think the EQ leading the charge for the next try <- open to suggestions on what to try next, even if it isn't on my list of possibilities.
Engine spec:
998+0.020"
ported 12G295 with biggest valves that'll fit
ported inlet manifold
Maniflow LCB
Twin HS2s with K&Ns
Thanks.
 Post subject: Re: SU Needle Help
PostPosted: Sat Apr 05, 2014 1:51 pm
Have you seen this chart?
http://www.google.com/url?sa=t&rct=j&q= ... tXCMr6rxKQ
PostPosted: Sat Apr 05, 2014 6:11 pm
Thanks for that. I'll have a bit of a play and see what it comes up with.
PostPosted: Sat Apr 05, 2014 6:26 pm
depends on the position of the dashpot pistons - is it lean under load or gentle acceleration or???
http://www.morrismini.com/SUNeedlesV2.a ... &size=.090
PostPosted: Sat Apr 05, 2014 6:38 pm
Hey Simon, it's lean under both gentle acceleration and under hard accel. It is more noticeable under hard accel.
PostPosted: Sat Apr 05, 2014 10:45 pm
This tool is GREAT also for comparing needles:
http://www.mintylamb.co.uk/suneedle/
I have used it heaps, and it works.
PostPosted: Sun Apr 06, 2014 6:59 am
That's the site that I have been using to come up with my original list of possibilities. Its a good site.
PostPosted: Sun Apr 06, 2014 9:15 am
I've often found if the Ms are too lean, AH2 works fine.
Stick em into mintylamb site and have a look. 8)
PostPosted: Sun Apr 06, 2014 6:20 pm
Thanks for the help guys. The clutch in the brides car is haddit so I spent some time today getting the mini in top shape and whipped the needles out and spent some time with some sandpaper and the drill around stations 4-7 with blending 3 to 4 and 7 to 8. Must say it worked out superbly as I picked a few dimensions from a couple of the other needles people suggested and worked towards a blend of GY and an average of the others to get something that feels perfect everywhere and idles beautifully.
