It is currently Fri Aug 15, 2025 3:24 pm
 Post subject: No Gary No
PostPosted: Thu May 01, 2014 10:41 am
Soo my mini doesn't want to give up smoking.... even with a new engine.
Would like your opinion on what might be causing this, as I believe it's oil and not over fueling. Suggestion being the head
1275 from a clubby. Running on xld classic oil and probably poor quality fuel
This "great running engine" was just bolted in from one car straight into mine. I didn't see it run before hand so unfortunately I cannot compare. Not that that matters, I just need to fix it.
** Don't mind the boofheads in the background =D **
http://s1229.photobucket.com/user/cal_9 ... 6.mp4.html
'63 850/1100 + more cooper goodies
 Post subject: Re: No Gary No
PostPosted: Thu May 01, 2014 12:03 pm
Valve guides & seals maybe?
When it sits, turned off for a while , does it blow smoke initially on startup ?
PostPosted: Thu May 01, 2014 12:27 pm
definitely valve stem seals, especially on the inlet. You can change them on the car without removing the head. Just need the right spring compressor tool and air line fitting into the spark plug hole.
66 MK 1 Cooper S
64 Grp N Cooper S
64 Grp N Cooper S (ex Bob Asher)
64 GRP N Cooper S (ex Fred Burley)
PostPosted: Thu May 01, 2014 3:47 pm
If you dont have a compressor and spark plug adaptor you can also put some thin rope in the spark plug hole then turn the engine over by hand to lock up the cylinder
PostPosted: Thu May 01, 2014 3:55 pm
If you are handy with a spanner, and have a torque wrench, taking the head off on a mini is a walk in the park compared to most cars anyway. Some say they can do a headgasket change in an hour - but you may need the head machined (another $80 or so - skim it a little more to increase the CR ;))
PostPosted: Thu May 01, 2014 4:50 pm
+1
PostPosted: Thu May 01, 2014 7:12 pm
If you didn't see it run in the original car its pretty hard to tell...
I had an engine that had great compression but stuffed scraper rings.. I would check the guides and valve seals but be prepared for this not to be the problem
Cheers, ian
PostPosted: Thu May 01, 2014 7:27 pm
Guides & seals.
PostPosted: Thu May 01, 2014 8:27 pm
How much to get them replaced? Any rough estimate available from someone in the know.....
I think mine are kangaroo edward....
Cooper S Mk2
Cooper S Mk1
PostPosted: Thu May 01, 2014 8:47 pm
New std guides are less than $50 a set.
Valve stem seals come free with the gasket but they are cheap crap. They go hard then no worky.
Good valve seals that last (Viton ones) cost more, but don't go hard. You really only need these on the inlets. Over $7 ea to buy here.
I got some from USA a while back, were less than $5 ea including postage.
PostPosted: Thu May 01, 2014 8:52 pm
Thanks Doc!
Cooper S Mk2
Cooper S Mk1
PostPosted: Thu May 01, 2014 11:00 pm
Goodie I would say it doesn't really blow any more smoke when I start it, but it is plenty slow to turn over (proper cr compared to the old 1100 me thinks) and requires almost full choke until warm
Pretty disappointed to confirm something s worn Tbh. Lot of time and money where I could've done my old motor... which I'm realizing now had alot more power than I first thought lol
Users browsing this forum: No registered users and 212 guests
