It is currently Mon Jul 28, 2025 7:38 pm
PostPosted: Tue May 06, 2014 9:08 pm
I have thought about doing it that way too Norm I just worry about the finish, if you could take some pics that would be great. So many different style and ways to set up.
Thank you everyone for the input keep it coming.
PostPosted: Wed May 07, 2014 5:10 pm
found this website too, a basic dash but comes with full fitting kit as well http://www.custom-consoles.co.uk/shop/c ... k/p41.html.
i have a custom dash template from mini forum but its too use with custom dials
https://www.dropbox.com/s/35sdc485ooy31 ... ed_RHD.pdf
which looks like this, i only wanted it as a rough size guide, i found the template was about 30mm too short .once i cut it all out & mounted it on cardboard for a test fit
PostPosted: Thu May 08, 2014 9:55 pm
Thanks Wallie good options for customisation too.
Next question.... They keep coming. Did any of the three piece dashes come out vinyl wrapped?
a guy at work gave me one today, I was thinking it was someones home made job though?
i peeled a corner of the vinyl back I don't think it is a traditional one.
It looks like it's made of plywood the gloveboxes and center piece are laminated timber.
A number marking on the back.
PostPosted: Fri May 09, 2014 6:10 am
lots of different ideas on the mini forum post
http://www.theminiforum.co.uk/forums/to ... directory/
PostPosted: Fri May 09, 2014 8:39 am
I shouldn't of looked at this while at work..... great thread!
PostPosted: Fri May 09, 2014 5:50 pm
It would probably be the BMC Australia accessory varnished wood dash that someone has stuck vinyl over, they had numbers on them so that the wood pattern matches on each piece.
PostPosted: Fri May 09, 2014 7:06 pm
check this out its a glove box that looks to fit from the far left to the gauge cluster
http://www.ebay.co.uk/itm/Classic-Mini- ... 19eba38f90
PostPosted: Fri May 09, 2014 7:26 pm
Check out these guys, I was looking at some of their stuff when I was going to put a custom dash in my mini
http://stores.ebay.com.au/customconsole ... minicoltd/
