It is currently Fri Jul 18, 2025 10:16 pm
 Post subject: Radiator Number stamping
PostPosted: Tue May 13, 2014 12:26 am
hi Guys,
just wondering if the number stamping on the radiator support for the 1969 Mini Cooper S has the same size font and style from the first to last number?
ie is the YG2S4 the same size as the 5??? number stamped after?
thanks in advance
PostPosted: Tue May 13, 2014 5:54 pm
From memory they are usually two different sizes, depths and fonts.
PostPosted: Tue May 13, 2014 7:41 pm
oh ok, the font on my mini is smaller on the yg2s4 and the number stamping after is slightly larger font
PostPosted: Tue May 13, 2014 9:49 pm
See here - viewtopic.php?f=2&t=85668
PostPosted: Thu May 22, 2014 9:43 am
modaddie wrote:
hi Guys,
thanks in advance
just a pedantic point on that, if you have a car with YG2S4 and then 4 digits starting with a 5, then there's something dodgy going on, those numbers didn't go past 3000 (actually 2919 or something)
and my numbers are the same font I think
PostPosted: Fri May 23, 2014 9:41 pm
oops my bad, it starts with a 5 but is only 3 numbers 547
PostPosted: Fri May 23, 2014 10:00 pm
Early one.
Does it have a body plate like the MK1 S
PostPosted: Fri May 23, 2014 10:22 pm
no its only got the stamping on the radiator support, and a number stamped in the channel above the wiper motor
PostPosted: Fri May 23, 2014 10:44 pm
Thanks. I think that was the case for the first 6 months or so. I have seen a couple with Mk1 Body Plates but they have all looked too clean to be original. Probably the owners wanting to have a plate on there for looks.
PostPosted: Sat May 24, 2014 9:27 pm
With my GT I know it is YG2S8 looks like a set stamp evenly spaced etc, and then the numbers afterwoods are in a different size and look hand stamped
