It is currently Fri Jul 25, 2025 6:26 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun May 11, 2014 5:26 pm
Yep a buggered lifter or push rod can cause a bad rattle. Usually comes with a buggered cam shaft
I hope its an issue with the top end.
Have a look at the top of the valve. Is there any mushrooming of the valve stem.
PostPosted: Sun May 11, 2014 5:49 pm
Hmmmm I wondered that might be replacing rod and said lifter. But will pull valves out as well for inspection
PostPosted: Sun May 11, 2014 6:01 pm
Thats not ideal
PostPosted: Mon May 12, 2014 3:01 pm
Goldbrocade_62 wrote:
Might be the pic but some off the rockers look close to the washers
I was going to say that. Is it the rocker hitting the cover? You will have this sort of problem with those newer alloy rocker covers, it p#ssed me off so much I went back to an original cover.
Lillee - 1969 Morris Mini K
PostPosted: Mon May 12, 2014 3:12 pm
simon k wrote:
why does the little stud on #2 have an extra washer on it? I bet someone has damaged that thread, stripped the nut and put the extra washer on it to pack it up. Shouldn't be using nylocks on those either
Simon, that extra `washer' is the keep plate for the rocker shaft grubscrew.
I think perhaps late motors had nyloc nuts on the 4 little studs, I've seen them on quite a few.
PostPosted: Tue May 13, 2014 8:07 am
Thanks guys all your input is appreciated. Off to buy a valve spring compressor today
PostPosted: Tue May 13, 2014 8:09 am
Nah i roll an original rocker cover
PostPosted: Tue May 13, 2014 6:15 pm
If you want a secondhand one I have a few mini specific ones.
Pm me I will do a fellow kiwi a good deal
Kiwiinwgtn
PostPosted: Thu May 15, 2014 7:32 pm
aaaw bro! I just gone and bought one today, i should of checked back here first! oh well thanks for the offer any way mate
PostPosted: Thu May 15, 2014 9:29 pm
No worries.
Fingers cross you get to find what the issue is.
Kiwiinwgtn
PostPosted: Fri May 16, 2014 11:52 am
just pulled the exhuast valve from pot 1......yep! its bent it wouldnt slide out nicelt like it should could this be the culprit?
PostPosted: Fri May 16, 2014 9:40 pm
Valves do mushroom on the end.
I usually use an oil stone to debur the top of the valve before I try and push it thru the guide.
They should just push out by hand with little resistance.
To check to see if its bent see if will roll easily on a glass table top. Or use a straight edge.
Hopefully the valve will have a mark on the stem showing you have found the issue
When it happened on my car the valve guide grabbed the valve which wore the guide.
With the valve out does the guide look round
I am sure I posted a pic of my buggered valve guide in one of my posts
Kiwiinwgtn
PostPosted: Sat May 17, 2014 2:32 am
ok ill get a photo up when i get a spare moment.
i also removed exhaust valve from pot 2. iy glided out sweet then i inserted into the guide on pot 1. it went in nice too .on the bent valve there is a polished rub mark on the stem . the guide appears to be ok but i could be wrong
PostPosted: Mon May 19, 2014 10:31 am
After fighting with windows 8.1 :evil: I managed to enlarge the pic and No7 rocker arm/cylinder 4 inlet is hitting the washer on the rear stud. The others look pretty close too.
RonR
68 build Mk1 Cooper S
PostPosted: Thu May 22, 2014 7:59 pm
The guide is the issue. They grab the valve, piston comes up and whacks the valve,
I would check all the guides. Replace it. I bet it is oval
