It is currently Sun Aug 03, 2025 12:33 am
 Post subject: Cleaning calipers
PostPosted: Fri May 16, 2014 5:57 pm
I've removers mine off the front end whilst replacing hoses etc. I just want to give them a small clean up . Can I soak them as is in some hot soapy water or do I risk getting water past seals etc.
 Post subject: Re: Cleaning calipers
PostPosted: Fri May 16, 2014 6:02 pm
as long as hose holes a blocked, soaking them is fine. Try scrubbing with jiff or similar.
PostPosted: Fri May 16, 2014 7:07 pm
Don't use degreaser to clean them. If you need a solvent, use metho.
PostPosted: Fri May 16, 2014 7:16 pm
Yeh holes are all blocked I'm keeping them out in case back of caliper won't be seen.
Sweet as Cheers
