phillb wrote:
justminis wrote:
Hi Linton
Welcome to the forum. The ID plate for my 1966 Mk 1 Cooper S also has the engine number neatly stamped from behind, the same as all the other stampings on the plate. I've always taken this to indicate that my car was a special order from the factory. It is one of the few factory black Mk 1 S's about. I also agree that your car sounds like its got the right bits and numbers except for the rubber cone suspension. My car was also converted to rubber cone suspension early in its life as it too has a competition history.
Yes, I think the explanation could revolve around the car being handled or assembled differently for some reason, (special order, or a problem or fault which meant the car was removed from the line), perhaps in justminis case "BLACK" was not normally setup in the plate stamper so they prepared the plate later/separately.
I like this idea (although a strong case would have to be put with a few extra examples) as the machine to create the custom plate is separate from the series production of plates which would have taken place when their production is in the order of thousands at a time. The plate is created separately prescribing a particular engine to a car number. When married up the car number may then differ due to quality control issues.
I would put as above, a plate created at the side of the production line because of a car out of sequence with the rest, a lost plate, an unexpected number, an engine which has turned up out of sequence because of rework or a manufacturing error in the plate or car numbering. There will be real world reasons for an ad-hoc plate creation at the assembly line and probably quite reasonable when explained in a real world context of manufacturing errors.
