It is currently Fri Jul 18, 2025 4:16 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
Would you buy one?
Yes 92%  92%  [ 36 ]
No 8%  8%  [ 3 ]
Total votes : 39
PostPosted: Tue Jul 01, 2014 1:34 pm
While you are at it can you make an Ausmini Camber/Castor gauge?
Yes please!
PostPosted: Tue Jul 01, 2014 5:54 pm
A slightly better version...
PostPosted: Tue Jul 01, 2014 6:04 pm
What width do they need to be to suit mini wheels, or does it even matter?
Do you measure across the rim or the sidewalls?
PostPosted: Tue Jul 01, 2014 6:08 pm
It needs to sit on the rim and not the sidewall for the best accuracy.
That photo is slightly skewed and will probably need redrawing.
PostPosted: Tue Jul 01, 2014 6:45 pm
Ok, so one does not fit all.
Do people trim them down to fit the edge of the rim's lip?
PostPosted: Tue Jul 01, 2014 7:01 pm
The one I used way back in 1982 was a sheet of alloy with a 90° fold of about 25mm.
If you make it suit a 10" wheel the blokes with 12's or 13's just need to slide it forward or back to touch both beads of the rim. It does not have to be centred on the rim, it just needs to be vertical.
PostPosted: Tue Jul 01, 2014 7:07 pm
Rodger.
PostPosted: Tue Jul 01, 2014 7:17 pm
Here is the directions for using one of these gauges...
https://www.merlinmotorsport.co.uk/file ... geinst.pdf
PostPosted: Sat Jul 05, 2014 1:32 pm
The wheel gauge tho' specifically for a mini, would work on the MG?
PostPosted: Sat Jul 05, 2014 1:39 pm
nvm, I misread the Q.
Last edited by drmini in aust on Sat Jul 05, 2014 4:19 pm, edited 1 time in total.
PostPosted: Sat Jul 05, 2014 3:06 pm
Actually it would probably foul the centre of the wheel on an 1100 due to the offset.
It is very easy to make an attachment to make it work.
PostPosted: Mon Jul 07, 2014 4:27 pm
You need to put on "Cooper S" degree wheel so people will pay instead of making their own. Maybe you could also put on a final drive measure. Say on the back side a continuous arrow around the circumference to represent one drive shaft revolution.
PostPosted: Mon Jul 07, 2014 7:00 pm
This may be slightly off topic but still on the promotion and love of Ausmini.... Stickers !! not degree wheel stickers but the Ausmini Logo.
About 6 inch long i think. Id buy half a dozen, even put one on the fridge just to annoy the wife :) haha
PostPosted: Mon Jul 07, 2014 7:05 pm
I'm doing some plotting when I get a few moments to create a template which will be correct.
Its important given the role of the Camber/Castor gauge that I spend a few hours to get the geometry correct.
There's a little bit of trig, but its not too bad :)
Yeah I can have a few stickers made up. You're right, the logo is a pretty inspired piece of artwork :)
I've certainly seen worse artwork on a website...
I'll see what I can do. I'm not a fan of big square stickers. I'll see if something tricky can be done.
Mick
PostPosted: Mon Jul 07, 2014 8:42 pm
I'd be in for a few vinyl cut logos. Perhaps 3" would suit the mini rear window better...
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
