It is currently Tue Jul 22, 2025 9:06 am
PostPosted: Sat Jul 26, 2014 4:56 pm
Quick question , Would a set of door rubbers from a 64 850 fit on a 68 deluxe ?
Some one offered me a new spare set from his 850 but I'm not sure if they will fit my deluxe doors ?
Cheers Jarrad
PostPosted: Sat Jul 26, 2014 5:31 pm
The door rubbers for the 64 850, if they were intended for the original sliding window doors are thicker than the later type. You will need to look at the cross section to determine which door they are for.
PostPosted: Sat Jul 26, 2014 8:43 pm
Ok thanks mick , he has sliding window doors on his so they would be thicker seals than I have ,
Would I be better off with these :
http://minisport.com.au/door-seal-suit- ... 850acooper
PostPosted: Sat Jul 26, 2014 9:21 pm
That is the correct type. Note that they will be unnaturally tight at first, but will settle in over time.
PostPosted: Sun Jul 27, 2014 11:54 am
Thanks for the help mick [SMILING FACE WITH OPEN MOUTH AND SMILING EYES]
PostPosted: Sun Jul 27, 2014 6:59 pm
why do I have so many pieces of pinchweld that I've taken out of cars with windup windows? I have door rubbers in my S from rarespares that are held on with the pinchweld that was on it when I got it...
PostPosted: Sun Jul 27, 2014 7:04 pm
Years ago (when I didn't know better) I bought 850 door rubbers in from Minisport UK, and tried to use them on my windup doors. There was about a 1/8" gap, the 850 ones were smaller than the Oz Deluxe etc ones.
I fitted local Deluxe etc door ones and they sealed fine.
PostPosted: Sun Jul 27, 2014 8:01 pm
I seem to recall a while ago someone mentioning that there was a Ford door rubber that was the same profile? I could be wrong there is so much stuff that comes up on here it is pretty easy to lose track of things.............
PostPosted: Sun Jul 27, 2014 8:22 pm
XD Falcon rubber fits windup doors, can buy off the roll at Grippy Rubber, Clark Rubber, etc.
Measure first, they are longer than you think... :wink:
PostPosted: Sun Jul 27, 2014 8:55 pm
that's the sort of info that needs to be stored somewhere.
PostPosted: Sun Jul 27, 2014 9:17 pm
I was told that ford rubbers fit as well from a few people
Ive said it here before
PostPosted: Sun Jul 27, 2014 9:25 pm
I was crawling through CLark Rubber only a few days ago, they're a few dollars more than buying them of the roll locally from a mini supplier, but they have a number of different cross sections of different sizes there.
PostPosted: Mon Jul 28, 2014 10:18 am
Thanks for all the info guys
PostPosted: Mon Jul 28, 2014 6:42 pm
So Kev, do you still have the 850 seals??
Cheers, Ian
PostPosted: Mon Jul 28, 2014 8:44 pm
Cheers, Ian
Haha, it was 20+ years ago, I binned them then. :lol:
ps. they had taken 10 WEEKS to get here from UK, as some dill at Minisport put them on a SHIP!! :roll:
