It is currently Tue Aug 05, 2025 4:57 pm
 Post subject: Speedo Calibration?
PostPosted: Sat Aug 09, 2014 8:36 pm
I've come to the realisation that the speedo in my 76 clubmand is wrong by a good 10-15kph. It reads about 75ish when I'm really only doing 60.
Has anyone else got this problem and is there a way to fix it without having to get any new parts? ie; is it just a recalibaration job?
-----Better is the enemy of good-----
-1976 Yellow Devil Leyland Clubman-
-1970 Morris Mini Van - Work in progress-
 Post subject: Re: Speedo Calibration?
PostPosted: Sat Aug 09, 2014 9:10 pm
Mines the same in a 74 model ive tried 2 speedos now both the same we just use a garmin or tom tom gps now
PostPosted: Sat Aug 09, 2014 10:16 pm
Mine under-reads all the time, what ever speed I'm doing it reads zero! Like drjbeam I rely on Tom Tom
PostPosted: Sun Aug 10, 2014 11:52 am
Still better than mine. All mine does is 360's round and round the faster I go the faster its 360's.
Then if I go in reverse it does 360's in reverse.
I need to do something about it. When I can be bothered.
PostPosted: Sun Aug 10, 2014 12:16 pm
This is a pretty dodgy method but worked for me.
You need to pull it apart enought that you can have the needle not resting against the stop post and note where it tends to sit. Then turn the needle backward, more than 360 deg may me needed, until it's new rest spot is equivilant to about 10kph. Might take a bit of trial and error and mine was a large early speedo so I'm just assuming will work in same way.
The smiths speedos if calibrated correctly are actually quite accurate.
A better way would be to give it to an instrument repairer.
PostPosted: Sun Aug 10, 2014 5:15 pm
phillb wrote:
The smiths speedos if calebrated correctly are actually quite accurate.
Funny that people will service a car every 5000km but they expect a speedo work for 50 years without a service.
PostPosted: Mon Aug 11, 2014 9:39 am
i had enough of replacing speedo's so i bought a digital 1 with a speed sensor that fits the mini gbox, its a bit of a pain too setup with 10" wheels but works a treat i got it from digital speedo's in the UK
PostPosted: Mon Aug 11, 2014 10:43 am
Man! I'd love to see that :!: 8) :lol:
The return spring has broken or come adrift, it may be a simple fix...
[PS its obviously bashed its way past the zero post enough to bend it over as well...I'd say]
PostPosted: Mon Aug 11, 2014 10:46 am
What's funny about it :!: :P (signed Mick, ex-clock-winder)
PostPosted: Mon Aug 11, 2014 11:39 am
Is there anyone in the Sydney area that recalibrates / repairs Smiths speedos and gauges? I know Howards in Vic are highly recommended, just wondering if anyone has used someone more local?
PostPosted: Mon Aug 11, 2014 11:45 am
Never used them, but l have driven past there a couple of times
Attspeed Auto Instruments
Speedometers - St Marys, NSW
Unit 1, 35- 37 Glossop St, St Marys NSW 2760
Phone
(02) 9833 0055
1993 R32 Nissan Skyline GTR
PostPosted: Mon Aug 11, 2014 5:10 pm
South West Instruments
used to be at Smeaton Grange , Heard he was working from home now
Can't find his details , think he may have advertised in previous editions of the BMC experience
PostPosted: Mon Aug 11, 2014 7:25 pm
I used these guys 30 years ago for an S speedo repair & calibrate, I dunno if they still do repairs or just sell new stuff.
http://www.olympicinstruments.com.au/c- ... otive.aspx
ps. They weren't cheap....
PostPosted: Tue Aug 12, 2014 5:11 pm
there is also....St George Instrument Services, 91 Planthurst Rd Carlton NSW 2218
PostPosted: Tue Aug 12, 2014 5:55 pm
Podge
I have a speedo repair PDF " Jaeger & Smiths " if you'd like it ...... its around 1 mb so can probably email it to you.
So if you want a copy just pm me your email addy
Cheers Bill
