It is currently Sat Jul 19, 2025 12:35 pm
 Post subject: Drive Shaft
PostPosted: Wed Sep 17, 2014 6:46 pm
I've just bought a Mini to restore and it has a Cooper s front disc brakes and Hardy Spicer drive shafts. The car didn't have a engine but a found a 998 cc engine with rubber cross drive system. Should I buy the parts to fit Hardy Spicer flange to the diff or convert it to a Pot Shaft drive.. :?:
 Post subject: Re: Drive Shaft
PostPosted: Wed Sep 17, 2014 6:59 pm
Well the splines on the S driveshafts you have will also take the rubber joint yoke.
But I'd not do this as the rubber U/Js are rubbish now.
Most folks go for pot joints- they give less power loss than H/S joints, and the parts are much cheaper.
You will need to pull the diff out, fit pot joint diff shafts, and swap your driveshafts for pot joint ones.
PostPosted: Wed Sep 17, 2014 10:24 pm
The Mini King
PM Sent
Users browsing this forum: No registered users and 69 guests
