Well the splines on the S driveshafts you have will also take the rubber joint yoke.
But I'd not do this as the rubber U/Js are rubbish now.
Most folks go for pot joints- they give less power loss than H/S joints, and the parts are much cheaper.
You will need to pull the diff out, fit pot joint diff shafts, and swap your driveshafts for pot joint ones.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
