It is currently Fri Jul 18, 2025 1:52 pm
 Post subject: Clunk noise
PostPosted: Thu Sep 18, 2014 2:01 pm
When driving my MK11 Cooper S home before I started the strip down I noticed a clunk noise when on off the accelerator,as I am pulling the car down I thought that Somebody might be able to give me a heads up as to what the problem might be.I grabbed the top of the engine but can't rock it back & forward even though the stabiliser rubbers look worn.
cheers.
 Post subject: Re: Clunk noise
PostPosted: Thu Sep 18, 2014 2:29 pm
It could be the rubber mount where the remote change housing bolts to the body underneath? Mine had a similar clunk before I changed it..
PostPosted: Thu Sep 18, 2014 2:39 pm
It is easier to test the engine movement by putting it into gear, handbrake off and rocking the car back and forth.
PostPosted: Thu Sep 18, 2014 2:44 pm
Check the big CV nut on each hub, if loose that gives a good clunk.
Usually it means the drive flange and/or CV's spline is worn.
