It is currently Tue Jul 15, 2025 11:20 pm
PostPosted: Fri Sep 19, 2014 8:11 am
It's a stupid question, I know, but did anyone ever make an aftermarket single carb manifold to suit an HS2? Would be cool on an 850...
PostPosted: Fri Sep 19, 2014 8:21 am
I'd think someone, somewhere would have made one. I'm sure maniflow could get get a steel one made up similar to the 1 1/2 ones they do
http://www.maniflow.co.uk/index.php?vie ... oduct=1098
Minisport also do a 1 1/4 to 1 1/2 adapter bracket to use a common HS4 manifold
http://minisport.com.au/mini-su-adaptor ... n-to-1-1a4
PostPosted: Fri Sep 19, 2014 8:22 am
Never thought about an adapter. Cheers!
PostPosted: Fri Sep 19, 2014 8:38 am
Looking at the brochures on http://mk1-performance-conversions.co.uk/ , Oselli looks to have done "gas flowed" original type manifolds. You could also expect some gains in separating the inlet and exhaust manifolds to avoid the heat transferring into the inlet...
PostPosted: Fri Sep 19, 2014 8:59 am
I'd put a single HS4 on it. All the automatics got this, including 850 autos in UK. It's worth a couple of HP over an HS2. :wink:
It was done to offset power loss thru the autobox.
PostPosted: Fri Sep 19, 2014 10:33 am
Lynx made one but I don't no if it suited hs4 as well I'd need to look on the van to confirm
PostPosted: Fri Sep 19, 2014 3:44 pm
I have a used alloy LYNX mini manifold that has can fit a HS2 or a HS4 or a HS6, it is for sale, PM if you are interested. cheers Caleb
PostPosted: Fri Sep 19, 2014 4:22 pm
Thanks for that! Not interested at this stage, it was more for an educational endeavour.
PostPosted: Fri Sep 19, 2014 5:24 pm
my thoughts are regarding what issues if any the eddys caused by a smaller throat HS2 for example, would cause?
It's easy once you know how.
Users browsing this forum: Barkfast and 88 guests
