It is currently Tue Jul 22, 2025 12:15 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 20, 2014 3:41 pm
Just bought a Century 67 620CCA battery for $140 on special at Supercheap.
That'll start the bastard! :wink:
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Sep 20, 2014 3:49 pm
Same one spins my 11.0:1 1360 just fine, Lucas starter and all. 8)
Century batteries are pretty good. I got 8 yrs out of a marine one in my boat once (20 years ago). Most others used to die in it @ around 4-5 years.
PostPosted: Sat Sep 20, 2014 5:15 pm
Sweet!
Thought it looked like a good choice....thanks Doc! :D
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Sep 20, 2014 10:52 pm
What is regarded as a good battery life, as I just put the biggest one I could fit in the hole and I have had it for 11 years, although it is starting to get a bit weak now. I'd say i'll be replacing it soon.
PostPosted: Sat Sep 20, 2014 10:57 pm
You are willing to spend $450 on a battery for a vehicle you use once a month? Please tell me you're not serious...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Sep 20, 2014 11:22 pm
And how l spend my money is your concern, is it?
1993 R32 Nissan Skyline GTR
PostPosted: Sun Sep 21, 2014 1:46 am
Let me know if you end up getting the Braille Dave, I'd be interested to see how it goes
PostPosted: Sun Sep 21, 2014 5:16 am
Hey chux. Ive had it for while and no dramas firing up the mini. The only thing l do is put it on a trickle charger to top up the battery for a hour or two, when the car is stationary for a considerable amount of time. New battery vs old from memory was a 12kg difference.
Installed with there bracket
PostPosted: Sun Sep 21, 2014 3:21 pm
Agreed, unless it's for a race car :)
PostPosted: Sun Sep 21, 2014 3:59 pm
I have a tiny solar panel I picked up from Jaycar a little while back. I hook that up to my battery and keep it on the back parcel tray. It provides 20 mA (0.020 Amp) when the sun is on it, but will charge off the garage lights too (to a lesser extent). Its not a clever charger, but once it is up to voltage then 20 mA is dissipated by the battery quite simply as heat you will not detect.
PostPosted: Sun Sep 21, 2014 4:00 pm
I could never buy a battery that costs more than I paid for my Cooper S. :mrgreen:
PostPosted: Sun Sep 21, 2014 4:10 pm
What was the difference between the Carbon one and the standard one Dave? Other than the price :P
PostPosted: Sun Sep 21, 2014 5:03 pm
Just in case anyone needed to know:
If you take a 10+ year old unknown brand unknown CCA battery, completely short it for maybe 10-15 seconds (just enough so nothing catches fire), recharge it, use it for maybe a month to test and trouble shoot a rewired car, drain it testing new headlight relays, charge it again, let it sit a few weeks, charge it again, it will JUST have enough to turn a motor enough to get oil pressure. Just. Start it? pfft :wink:
http://www.mini-hb.co.nz
PostPosted: Sun Sep 21, 2014 5:34 pm
Nothing in weight, just looks and they have to be ordered there not usually kept in stock.
