It is currently Sun Jul 27, 2025 8:57 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 21, 2014 11:11 pm
I pulled the diff out. The diff gears were moving a bit on the pin. They diff gears were moving side to side and axially. I have not seen a new one so I have no reference. Apart from that there was nothing mentionable........ I might take he diff in to a mini joint and have em look at it.
blokeinamoke wrote:
PostPosted: Sun Sep 21, 2014 11:23 pm
I found this spring on the ground just after I pulled the diff....
Might be relevant ? Or just some rubbish I had laying around on the floor?
Image post editted by Mod winabbey
blokeinamoke wrote:
PostPosted: Mon Sep 22, 2014 7:13 am
If it's a rodchange box that's the main gearshift detent spring. It lived under the RH diff side cover. There was a steel ball behind it too... :wink:
PostPosted: Mon Sep 22, 2014 8:54 am
Ahh fiddle sticks
How tight should the spider gears be on the pin ?
blokeinamoke wrote:
PostPosted: Mon Sep 22, 2014 9:15 am
When new they have around .004"? clearance.
When worn, the sky is the limit.
If the diff pin wears bad, it looks like this, just before it breaks and punches a hole in yer diff or gearbox housing- :shock:
PostPosted: Mon Sep 22, 2014 12:51 pm
Oh wow mine is no where near that bad. Most if the movement is on the thrust sides. Should I change out the axle gears too ? They look ok.
blokeinamoke wrote:
PostPosted: Mon Sep 22, 2014 12:54 pm
Just on a side note, if this is actually the problem I would get a noise both in forward and reverse right ?
blokeinamoke wrote:
PostPosted: Mon Sep 22, 2014 1:45 pm
No the axle gears will be fine.
If the pin is worn the spider gears are too- so replace both.
You won't get noise from worn spider gears, unless the gears have broken into pieces which can happen.
