It is currently Wed Jul 30, 2025 8:37 am
 Post subject: Brake booster
PostPosted: Mon Sep 22, 2014 9:13 pm
My 69 Cooper S has a Lockhead brake booster not the VH44 that needs rebuilding,Can anybody tell me who rebuilds them at a reasonable price.
Cheers.
 Post subject: Re: Brake booster
PostPosted: Mon Sep 22, 2014 9:21 pm
Hydroboost were locals who used to do them. www.hydroboost.com.au
Overseas is J and L spares who will sell you all the parts you require. http://www.jlspares.com/sealkits1.htm
Parts used to be difficult to obtain, but are a lot easier now.
They don't pull apart like modern boosters, and have a few extra parts, so call ahead who ever you use and make sure they know what a Lockheed 5 1/2 Servo looks like.
PostPosted: Mon Sep 22, 2014 9:22 pm
Hydroboost used to do them. Not sure of they still do. http://www.hydroboost.com.au/
Edit: You beat me Mick. :?
PostPosted: Mon Sep 22, 2014 9:59 pm
There is this on Ebay. Exchange for $335.
http://www.ebay.com.au/itm/MINI-COOPER- ... 41878ecb68
PostPosted: Tue Sep 23, 2014 8:00 am
Yes I had my booster done by them ,South Coast Brake Re-sleeving in Queensland ,they do an excellent job at a reasonable price , but you have to re-plate the pressed metal parts yourself ,I have just left mine silver ,as per the one on ebay ,looks really good .They are very good to deal with
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Sep 23, 2014 8:29 am
Thats not a bad deal. But from a do-it-at-home perspective only if the parts come back plated and your servo was truly shot. Often they need a set of seals and perhaps a rechromed pushrod. If the pushrod is rusty, the airvalve torn and the diaphragm blown then I would think it better value. Usually the diaphragm and air valve are fine.
PostPosted: Tue Sep 23, 2014 11:22 am
The guy at hydro boost said that he was not doing them anymore,he put me on to some people at Sherppton in Vic who said that I need to go to Hydroboost.I have rung the guy at Southport in Qld & he is only too happy to do the job.
Cheers.
PostPosted: Tue Sep 23, 2014 1:44 pm
Not sure which state you are in but you could post I guess. I just got mine done at vacair. Cost about $300- I think. I called hydroboost but he wasn't interested and told me to try vacair.
Vac Air Services Pty Ltd
Brake & Clutch Services - Thomastown, VIC
Clutch & Brake Reconditioning, Repair, Resleeving, Booster Services
38 Commercial Drv, Thomastown VIC 3074
(03) 9464 2122
Oh, and don't take a booster in that has already been disassembled, they were not at all happy! (even though I bought it that way) and didn't want to touch it.
Before
After
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Tue Sep 23, 2014 4:50 pm
Looks like there are a few people with good leads to help you out. I was chasing a Lockheed booster for my 'S' back in the '90's, as the local Brake company could not get the atmospheric valve for the booster.
I was put onto Jack Reid in Brisbane and he came up with the goods. I had a chuckle at the Mini Muster in 2009 where I first met Greg Coates. Who should walk up to Greg and hand him a booster, yes it was Jack. I've heard he is not well these days. Hang in there Jack.
PostPosted: Wed Sep 24, 2014 7:09 pm
its a perfectly simple DIY job ...as long as you can get the bits AND the internal bore is not damaged... Its like a slave or master and corrodes internally in the same way. There are several places that can reclaim the bore with a stainless sleeve... The external air return filter is the hardest part to get hold of IME.
Cheers, Ian
PostPosted: Wed Sep 24, 2014 7:20 pm
The problem I had with mine was the push rod had corroded and pitted where the seals sat
the guy that rebuilt mine ( Mark Smith ex Campbelltown Brake and Clutch ) had a new stainless shaft
made
All sweet now
PostPosted: Wed Sep 24, 2014 7:38 pm
I sent my Lockhead brake booster of to southport in Qld today to have it restored to original condition.Cost around $350.I have heard good reports about this guys work.His name is Dave .Phone number mob 0407172319. W/shop. 07 55324471.
