It is currently Sat Jul 19, 2025 9:45 am
 Post subject: Mini K or Cooper Dash
PostPosted: Tue Nov 18, 2014 2:30 pm
Quick question about dash binnacle. It was my understanding that the early cooper 100mph dash had 4 screws holding the front on and didnt have the lines on it or extra indicator lenses. Is this Dash from a mini K or a later Cooper S? Am I also right in thinking the temperature gauge has been replaced and is not original?
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Tue Nov 18, 2014 2:40 pm
Yes. You are correct.
PostPosted: Tue Nov 18, 2014 2:47 pm
Thanks
Is there any difference between a mini K and a cooper S early and late dash ?
2000 Honda CBR929RR
PostPosted: Tue Nov 18, 2014 2:48 pm
Is it held in place with 6 screws? The 1970 K/S one on my kitchen bench has 6.
Amazing what you can find when you are forced to crawl under the house!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Nov 18, 2014 2:59 pm
This is a photo of what is hidden behind the MK1 dash. They use the original single speedo housing and then 2 side brackets and then the oval backing plate.
The firewall is different on a Mini K and MK2 S as it has 2 extra captive nuts to screw the oval dash to it.
