It is currently Sun Aug 03, 2025 5:01 pm
PostPosted: Sat Jul 21, 2012 9:08 pm
I got a fuel pump blanking plate drilled small holes and brazed a breather at an angle to clear extractors and plugs up the same as above. This was information i received from matt read it worked really well.
PostPosted: Sat Jul 21, 2012 9:09 pm
Mine run fine off the rocker cover. One has a sealed filler cap, the other an S (breather) cap, makes no difference.
You can plumb the PCV valve into the manifold with SUs, or run a hose to the SU's vac port (without a valve) if it has this port. You can easily drill and fit one if the carb doesn't have it... :wink:
I found putting them on the fuel pump flange doesn't work (LOTS of oil from crank & rods over 4500 rpm) and on the flywheel housing is NFG on long LH bends at high rpm (lots of oil from primary gear).
PostPosted: Sat Jul 21, 2012 10:11 pm
thanks, do you need to block off the flywheel housing vent or can i still run a small breather
Also sorry of the thread hi-jack
Kiwiinwgtn
PostPosted: Sat Jul 21, 2012 10:25 pm
Kiwiinwgtn
It needs to be blocked off.
I use a bearing plate from a steering rack, just slot the holes a little and it's the right size and shape.
Like this- (you can add the pipe to the rocker cover if you want, it just equalizes crankcase pressure top to bottom).
PostPosted: Sun Jul 22, 2012 8:04 pm
Ah makes sense now. what are the fittings you are using also which way round does the PCV valve go
arrow away from the manifold or to the manifold
Ta
Kiwiinwgtn
PostPosted: Sun Jul 22, 2012 8:38 pm
The fittings are just push fit airline fittings (my local bearing shop sells them), threads are 1/4 BSP, the tube is 12mm OD nylon.
On the PCV013 valve there is a shiny radius on one end of the body- this goes to the manifold.
If there is an arrow (flow direction) on yours it goes TO the manifold,.
PostPosted: Mon Jul 23, 2012 9:00 pm
just been looking at my engine,I have a breather on the front timing cover will this need to be blocked off as well.
Kiwiinwgtn
PostPosted: Mon Jul 23, 2012 9:02 pm
Kiwiinwgtn
Yep, but If I had one there I'd hook that to the PCV valve, not the rocker cover. But I don't (I have belt drive cam kit), and room is tight there anyway in an Oz roundy.
PostPosted: Wed Nov 26, 2014 7:20 am
To connect the hose to the inlet manifold, did you need to drill a whole and tap the manifold ? What type of connector or brass eblow and size did you use ?
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Wed Nov 26, 2014 7:50 am
I've just added a breather to a new alloy rocker cover. Since the brass fitting is taper (supercheap..) I just drilled slightly bigger than the small end of the taper, and cranked it in there with some locktight. Don't know if the brass cut the alloy, or the alloy mangled the brass thread, don't care, it's tight and doesn't leak :lol:
If anyone would like to know how much oil a racy 1380 will spew out the flywheel breather and dipstick hole when it doesn't have a rocker breather and you pull 7k in a motorkhana, I can advise :wink:
http://www.mini-hb.co.nz
PostPosted: Wed Nov 26, 2014 5:36 pm
i see on a uk forum a question about breathers using the dizzy hole, on ECu driven machines? rather than just a blanking plug... i would have thought not the best place , but still give credit for someone thinking outside the square/ or circle as it may be
PostPosted: Wed Nov 26, 2014 6:22 pm
Anyone ?
2000 Honda CBR929RR
PostPosted: Wed Nov 26, 2014 6:35 pm
simo74 wrote:
Anyone ?
Depends on the manifold.
Redline or Warneford Weber manifolds have 2 tapped holes with plugs.
Threads in these are either 5/8 UNF (older manifolds) or 1/4 BSP (newer ones).
BMC factory single or twin SU manifolds if they have a plug already, are 5/8 UNF. As are Minispares single SU ones.
I use 1/4 BSP brass fittings from Pirtek. If fitting them to a 5/8 UNF threaded hole I use a 1/4 x 3/8 BSP reducing bush, turn the 3/8 BSP thread down to 5/8" dia and cut a 5/8 UNF thread on it with a die.
Anybody needs these 5/8 UNF x 1/4 BSP threaded reducing bushes, PM me and I'll make some up.
[edit] here's the Xmas tree of brass fittings on my now water heated Redline Weber manifold-
PostPosted: Wed Nov 26, 2014 8:04 pm
Thanks, wow every time I see your set up it has more brass on it .......quality.
2000 Honda CBR929RR
PostPosted: Wed Nov 26, 2014 8:23 pm
Fair bit going on there Doc.
Love the cable tie hose clamps also :lol:
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
