It is currently Mon Aug 04, 2025 5:18 am
 Post subject: Hub, build up sequence?
PostPosted: Fri Dec 12, 2014 4:31 am
I finally received these yesterday but l am concerned that l may build these wrong, from left to right in the pic is this right, and what's the fat washer for in the bag?
Thanks
1993 R32 Nissan Skyline GTR
PostPosted: Fri Dec 12, 2014 6:40 am
viewtopic.php?f=25&t=77858
Check this out in the how to section it is for a drum to disc conversion but includes assembling the hubs. Might help
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Dec 12, 2014 7:19 am
The clear plastic thing is a dust seal that goes on outside of the inner seal. The fat washer is the spacer shim that goes between the 2 bearings inside the hub.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Dec 12, 2014 7:46 am
thanks simo74 and boomini
PostPosted: Fri Dec 12, 2014 10:19 am
If you are having issues, getting the bearings in, stick it on a cook-top.
Nick
PostPosted: Wed Dec 31, 2014 8:44 am
I thought the white thing was a seal spacer to stop the rotating bearing contacting the seal! Was I mistaken ?
PostPosted: Wed Dec 31, 2014 8:52 am
You are mistaken, boomini is right. :)
The white plastic guy is a dust seal, off all those parts, it will be the closest thing to the diff.
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Thu Jan 01, 2015 8:59 am
The white plastic thing is a water/slush excluder, as said it goes against the CV body, and sits in the grooved seal.
It is a UK thing, all Oz Minis just had 2 normal seals the same as the outer one shown.
Users browsing this forum: Bing [Bot] and 84 guests
